ZXY007o0ePksrW7L
[SOLVED] Can I connect an arduino directly to GPIO using a 10k ohm resistor?
Wed Jul 10, 2019 6:33 pm
I know this is going to be very hacky. I'll make a proper solution later.
I need to build something with my raspberry pi on short notice, and I determined that it would be less time consuming to interface my Arduino running some of my pre-existing code with my Pi than it would be to port the circuit and the code to use the pi instead. I also determined that it would be easier to use a single-wire GPIO connection to communicate than actually setting up serial, which turned out to be a huge hassle. The arduino outputs 5V, but the pi can only tolerate 3V3. Can I just put a 10k ohm resistor between the arduino and the pi, or do I absolutely have to set up a voltage divider using multiple resistors? If I have to make a voltage divider, what is the acceptable voltage range?
Last edited by ZXY007o0ePksrW7L on Tue Jul 16, 2019 1:51 am, edited 1 time in total.
Re: Can I connect an arduino directly to GPIO using a 10k ohm resistor?
Wed Jul 10, 2019 6:38 pm
You need a voltage divider. Just a 2k2 to the 5V input and a 3k3 resistor to ground should do.
[edit] Corrected order of resistors.
Unreadable squiggle
neilgl
Wed Jul 10, 2019 6:49 pm
Yes - probably best to just use 2 resistors..
What Arduino is it? - some are 3V3.
Also what does the existing code do - you could put it on a (say) D1 mini then use mqtt to communicate with the pi / IOT...
ZXY007o0ePksrW7L
Wed Jul 10, 2019 7:15 pm
It's an Uno, and I know for sure it is 5V. The existing code checks an ultrasonic sensor and turns on a pin based on the values.
I'm limited to the resistors I have under my bed. Can I use 4.7k (yellow-purple-red) + 1k (brown-black-red) for a total of 5.7k as my "first resistor" and 10k (brown-black-orange) as my "second resistor"? According to my calculations, that should output 3.2 volts.
drgeoff
Wed Jul 10, 2019 7:16 pm
You need a voltage divider. Just a 3k3 to the 5V input and a 2k2 resistor to ground should do.
It is more usual to have the 2:3 ratio with the '2' to the Arduino output (not the 5 volt rail) and the '3' to ground.
drgeoff
Wed Jul 10, 2019 7:20 pm
Yes those resistors will be fine. But you don't really need the 1K. 4.7K and 10K will be OK.
Wed Jul 10, 2019 7:21 pm
Yes, you are correct. I have corrected my post. Thank you.
Unreadable squiggle
neilgl
Wed Jul 10, 2019 7:39 pm
Depending which ultrasonic sensor it is, you could connect it to the pi e.g. HC-SR04 works fine (with resistors).
ZXY007o0ePksrW7L
Wed Jul 10, 2019 9:15 pm
I'm going to keep the 1k ohm because with just the 4.7k, it will be 3.4V. I read somewhere that the GPIOs can tolerate 4V, but I'm not going to take the chance. The Pi is cheap, but not cheap enough that I would consider it expendable. I read that the activation threshold is 1.8V, so I'd rather have 3.2V and be safe.
My ultrasonic sensor is a Parallax Ping))). Those seem to require very precise timing to get accurate measurements. Is the pi precise enough? Because it is 5V, I would still need the divider for it.
If this forum supports it and I can figure out how, I'm going to mark this as solved.
Burngate
Re: How to change a title
Thu Jul 11, 2019 9:28 am
Just go to your first post, edit it and change the title - just like I've just done for this post!
