iptables not saving after reboot
Posted: Mon Jul 08, 2019 11:05 pm
by fredstar
Have a Pi 3B+ with latest Raspbian Buster with desktop installed
Have also installed a USB to ethernet dongle
Have installed and have up and running
Isc-dhcp server
Dnsmasq
Openvpn
Network config is as follows:
ADSL modem -> eth0 RPi ----> eth1 Pi -> switch -> home PC’s
I have followed a guide on the set up of the open vpn with iptables and using iptables-persistent to save the changes.
I used the following article to config iptables
https://www.instructables.com/id/Raspbe ... N-Gateway/
All works ok until the RPi is rebooted – it loses the iptables rules
Any idea what is going wrong?
Very new to all this linux stuff
Re: iptables not saving after reboot
Posted: Tue Jul 09, 2019 8:36 am
by epoch1970
Isc-dhcp server
Dnsmasq
ISC-dhcpd is a DHCP server, dnsmasq is a DHCP server and DNS server+cache/forwarder.
Running 2 DHCP servers on the same network is ill-advised.
Do you need both applications?
No idea regarding your iptables issue. The rules were either not saved or are not restored at boot.
From the command line, right after boot, use “iptables -L”, “iptables -t nat -L” to assess the situation.
If no rules were loaded see if running iptables-restore does anything useful.
Posted: Tue Jul 09, 2019 9:32 pm
by fredstar
Never knew DNSMasq was a DHCP Server
Will uninstall isc and config dnsmasq as the dhcp server
Will check the out put of the iptables command
Posted: Wed Jul 10, 2019 9:10 am
by fredstar
Output of iptables commands
pi@raspberrypi:~ $ sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
pi@raspberrypi:~ $ sudo iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- anywhere anywhere
From what I can tell none of the iptables rules load
Posted: Sun Jul 14, 2019 10:27 pm
by fredstar
Managed to resolve my issue by adding the following:
pre-up iptables-restore < /etc/network/iptables.rules
to
/etc/network/interfaces.
Posted: Wed Aug 21, 2019 6:53 pm
by bluenote
to
This isn't working for me, could you confirm? I can do iptables-restore < /etc/network/iptables.rules and that works.
Posted: Wed Aug 21, 2019 7:04 pm
by epoch1970
The “pre-up” bit is a keyword valid only in /etc/network/interfaces. Since the use of that file is deprecated, do not concern yourself with it.
You can add command “iptables-restore < /etc/iptables.rules” in file /etc/rc.local to get the iptables rules restored at boot time.
Posted: Wed Aug 21, 2019 7:52 pm
by bluenote
Thank you that suggestion worked.
