WillWam
Raspbian Buster - No Java Support?
Sat Jun 29, 2019 10:49 pm
I'm trying to install Java 8 on the new Raspbian Buster (Lite). Having no luck, I get an error when I run the following command:
sudo apt-get install oracle-java8-jdk
The error is:
Reading package lists... Done
Building dependency tree
Package oracle-java8-jdk is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
So is Buster not ready for Java? Has Java not included Buster as a good-to-use distro? Or am I doing it all wrong? Many thanks.
HawaiianPi
Re: Raspbian Buster - No Java Support?
Sat Jun 29, 2019 11:56 pm
Try apt search openjdk, and pick a version to install.
If you want Oracle Java you'll probably have to install it manually.
For Oracle Java 8 you could try the webupd8team PPA.
See this post: https://www.raspberrypi.org/forums/view ... 0#p1400092
Andyroo
Sun Jun 30, 2019 12:02 am
The release notes say
Oracle Java 7 and 8 replaced with OpenJDK 11
Taken from http://downloads.raspberrypi.org/raspbi ... _notes.txt
Sun Jun 30, 2019 7:15 am
The error is:
i am running a fully updated fresh standalone Raspbian Buster ( neither use NoobS crapware )
sudo apt update
sudo apt full-upgrade
sudo reboot
OpenJDK 11 is the default, but OpenJDK 10, 9 & 8 are in repositories:
opendk-10-jdk openjdk-10-jre
opendk-9-jdk openjdk-9-jre
opendk-8-jdk openjdk-8-jre
Last edited by fruitoftheloom on Sat Jul 06, 2019 8:40 am, edited 1 time in total.
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
Gavinmc42
Sun Jun 30, 2019 7:20 am
Will be interesting to see how Processing works on a Pi4 now.
Is the Pi4 fast enough to run Netbeans?
I found Java with JavaFX borderline on 3's.
So many old things might just work well now on 4's
I'm dancing on Rainbows.
Return to “Beginners”
