Raspberry pi 4 Large storage
Posted: Thu Jun 27, 2019 7:43 am
by Dekomoro
Im looking for an external hdd that uses usb 3.0 that would work with the pi 4.
Im preordering it and need it for storage uses
I still plan on using an sd card for boot however, and plan on booting multiple oses using the same storage
any suggestions???
Re: Raspberry pi 4 Large storage
Posted: Thu Jun 27, 2019 6:48 pm
by W. H. Heydt
Welcome to the forums.
The only USB 3 HDD specifically for the Pi, that I know of, is the WD PiDrive. Unfortunately, they are no longer made. There is also the question...what do you mean by "large storage"? How large? The PiDrive is 314GB.
If you use a USB 3 to SATA adapter, you should be able to connect any 2.5" HDD or SSD. For a 3.5" drive, you'll definitely need external power because they require 12v.
Posted: Thu Jun 27, 2019 8:31 pm
by Gythral
Any USB3 to SATA adapter should work
Then use a matching HDD/SSD
I alreay use one of the usb2.0 to mSata on a Pi3B, but the generic one does not do the USB boot! (genetic with a 256GB 1.8" mSATA SSD on it)
What would be useful is a list of models (and/or sources) of adapters that work for USB boot on the Pi3B/+ and later on the 4B (when this function becomes available)
Posted: Thu Jun 27, 2019 10:15 pm
by Dekomoro
What sata to usb adapter do you recommend????
Posted: Thu Jun 27, 2019 10:23 pm
by Dekomoro
Posted: Fri Jun 28, 2019 12:53 am
by Gythral
That looks like the right idea
The reason I went with the mSATA ssd (and adapter) was because it is clear that it will run off the usb power that the Pi will provide, which is the other thing you need to check (or use a powered hub)
Posted: Fri Jun 28, 2019 2:07 am
by W. H. Heydt
Actually... What would be even more useful would be feedback to the RPT engineers about which SATA bridge chips work and which don't so that they can see if they can tweak the EEPROM to handle more varieties. Let's at least leverage the ability to do updates to the "firmware" the Pi4B has.
Posted: Fri Jun 28, 2019 2:20 am
by HawaiianPi
If you are not booting from the USB drive, then any USB drive should work. You don't need anything special.
Posted: Fri Jun 28, 2019 3:51 am
by HawaiianPi
Actually... What would be even more useful would be feedback to the RPT engineers about which SATA bridge chips work and which don't...
If only it were that simple...
I have adapters from different companies with the same chipset that do and don't work.
I have adapters that work with some drives, but not others, while a different brand adapter with the same chipset will work with the drives that didn't work on the first adapter.
I have different model adapters from the same company, with the same chipset, that behave differently (Eluteng Black vs Blue).
It's likely the Pi4 will be, or can be made compatible with a wider variety of drives and adapters, since it does have upgradable firmware. Question is, how much time and effort will be needed to do that, and if the developers are willing.
Just be clear, I'm talking about USB booting with no SD card. I have had no trouble with any drive or adapter when booting from SD card and using USB drives as storage (that always works).
