4k3or3et
Autostart in Raspbian Buster...
Wed Jun 26, 2019 5:21 pm
Hi guys
in Raspbian 9 there was a file:
/home/user/.config/lxsession/LXDE-pi/autostart
where you could put some command which were executed by given user at boot.
In Raspbian 10 folder '/home/user/.config/lxsession' does not exist.
The thing is that i need to run command every single boot and the command needs to be executed by regular user not root.
i found '/home/fyahhaffibun/.config/autostart' but putting there scripts does not invoke them at boot (there are only *.desktop files which sort of .lnk equivalent in Windows i believe).
Where is the autostart which supports terminal commands in Raspbian 10?
Thank you.
gordon77
Re: Autostart in Raspbian Buster...
Wed Jun 26, 2019 5:37 pm
Try using /etc/xdg/lxsession/LXDE-pi/autostart
4k3or3et
Thu Jun 27, 2019 6:02 pm
That's the one. Thanks Man!
MarkDH102
Fri Jun 28, 2019 6:15 am
Sigh.
Why does Linux keep breaking "simple" things on each new distro?
Glad I found this as IF I ever update my 10 Stretch Pi's then I will have to make changes to them all regarding this issue...
I know Microsoft have had issues but I can still run VB6 compiled applications amongst other legacy software on Win10!
gordon77
Fri Jun 28, 2019 7:05 am
Nothing changed this distribution. This used be the place for autostart on the pi, but then a while back it changed to the /.config version, which l believe is the 'correct' location where linux should look if it exists. Then l think with Jessie distribution we went back to /etc... Which was a bit confusing but l assume still correct as /.config... doesn't exist now. Still a bit confusing though if things change.
sellaholics
Fri Jun 28, 2019 9:52 am
Thank you. I have the same problem. Anyone has another solutions?
klricks
Fri Jun 28, 2019 12:37 pm
What problem?
The solution was already given in the first reply above by gordon77.
use:
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
divest
Fri Jul 05, 2019 7:59 am
file /home/user/.config/lxsession/LXDE-pi/autostart
directory /home/user/.config/autostart/
also works
gordon77
Fri Jul 05, 2019 10:22 am
also works
Do you have to make that directory first, as its not there by default?
W. H. Heydt
Fri Jul 05, 2019 8:43 pm
An overall cleaner solution would be to create the user autostart and then, within it, execute the system autostart. That way, if a new version is installed, you get whatever changes are there and still run the stuff you want to.
As it is, if you modify the system file, not only does it apply to all users (bad idea), but it is subject to being overwritten any time you do a system upgrade. If you just create a local autostart, then nothing in the system autostart will be run unless you explicitly do so.
clemon79
Sat Jul 13, 2019 6:22 pm
I'm trying to do the same thing, except I''m just trying to execute an xinput command to flip my touchscreen digitizer input so I can use it upside down, specifically:
xinput set-prop 'TSTP MTouch' 'Coordinate Transformation Matrix' -1 0 1 0 -1 1 0 0 1
I'm on Buster, I've tried editing
(adding the line above, both with @ and without), I've tried creating
~/.config/lxsession/LXDE-pi/autostart
and editing that, and I've tried using the full path to xinput (using
which xinput
to find it; I don't remember it offhand) , but I can't get it to work. What am I doing wrong? This shouldn't be that hard and it's really frustrating.
klricks
Sat Jul 13, 2019 11:02 pm
which xinput
Try the command without any ' or "
@xinput set-prop TSTP MTouch Coordinate Transformation Matrix -1 0 1 0 -1 1 0 0 1
If that does not work the try this:
@lxterminal -e xinput set-prop TSTP MTouch Coordinate Transformation Matrix -1 0 1 0 -1 1 0 0 1
Note that if a file named autostart exists in /home/pi/.config.............. then the autostart at /etc/xdg/.......... will be totally ignored.
W. H. Heydt
Sat Jul 13, 2019 11:39 pm
That's why, if you create an autostart file in /home/<username>/.config you should start by having it execute the system autostart and only after that, add the additional commands you want to have executed.
clemon79
Sun Jul 14, 2019 12:17 am
Really,. that would parse? It would know that the device name is TSTP MTouch and that the specific property I want is the Coordinate Transformation Matrix? I'll give it a shot but you understand my skepticism. :)
EDIT: Yep, didn’t parse. Also when trying that at a terminal prompt (where it works fine in original form!) it told me it could not find the “TSTP” device.
clemon79
Sun Jul 14, 2019 12:34 am
W. H. Heydt wrote: That's why, if you create an autostart file in /home/<username>/.config you should start by having it execute the system autostart and only after that, add the additional commands you want to have executed.
Can you share what that would look like?
W. H. Heydt
Sun Jul 14, 2019 12:59 am
Assume the user name is 'pi'. Within an executable autostart file...
stuff I want to do.
More stuff I want to do.
clemon79
Sun Jul 14, 2019 1:03 am
stuff I want to do.
Okay, so no need for other syntax? For example, I could do:
...then chmod it 755 (or 644?), and that should work? (And what's the "@" sign mean in these autostart files?)
klricks
Sun Jul 14, 2019 1:53 am
stuff I want to do.
...then chmod it 755, and that should work? (And what's the "@" sign mean in these autostart files?)
Yes you can do it that way but it is optional and has nothing to do with whatever your issue is.
The @ is optional and is supposed to re-execute the command on failure. Not much more info on that that I can find.
In some cases a delay is needed before the command is executed to make sure the OS has completely booted and/or logged in before your command is executed.
To do that you would need to create a bash script and call the bash script from autostart.
#!/bin/bash
sleep(3)  # adjust delay as needed.
<your command here>
(Make sure your bash script works from the command line before trying in autostart)
Note: Do not attempt to put sleep commands directly in autostart. They won't work as autstart executes commands all at once..... Or it does not wait for the current command to complete before starting the next one.
clemon79
Sun Jul 14, 2019 3:23 am
Okay, well, first thing I am trying to do right now is just get an autostart working in .config/lxsession/LXDE-pi that calls the one in /etc/xdg/lxsession/LXDE-pi correctly. Apparently just making a text file with the line above and chmoding it (and I’m also not sure if ‘pi’ or ‘root’ should have ownership of the file) isn’t enough. Once I get that working (because that seems like the correct way to do it so it doesn’t get blown out after an update) I will worry about the touchscreen again.
That said, I did discover a way to do the xinput command entirely with IDs instead of strings:
 xinput set-prop 6 115 -1 0 1 0 -1 1 0 0 1
seems to work fine. So that’s now an option.
clemon79
Sun Jul 14, 2019 3:33 am
Solved my problem: adding the above line to the bottom of ~/.profile works perfectly. I think I’m set now!
jlingley
Thu Jan 23, 2020 7:42 pm
Hello Busters.
I am having issues autostart-ing a Scratch 3 sketch on my class' RPi 4s with a full version of Buster.
We used to be able to accomplish this on a RPi3 running Stretch and Scratch 2 by doing the following:
1. Add Scratch 2 to desktop
2. Create Scratch 2 Sketch to be autostarted (ie: test.sb2)
3. Run the following commands in terminal:
mkdir .config/autostart
cp  ./Desktop/scratch2.desktop  .config/autostart
nano  .config/autostart/scratch2.desktop
4. Then in Nano
Exec=scratch2  /home/pi/Desktop/test.sb2
We have used the suggestions in this forum to run the suggested /etc/xdg/lxsession/LXDE-pi/autostart command by typing the following in terminal:
mkdir /etc/xdg/lxsession/LXDE-pi/autostart
cp  ./Desktop/scratch3.desktop  /etc/xdg/lxsession/LXDE-pi/autostart
And in the new Nano edit:
Exec=scratch3  /home/pi/Desktop/test.sb3
Following this exact process above, the RPi 4 with Buster booted, however just shows a cursor.
Any thoughts?
Your suggestions will help hundreds of students looking to create headless paintings without reverting to legacy RPis.
klricks
Fri Jan 24, 2020 5:25 am
Hello Busters.
4. Then in Nano
Any thoughts?
I don't follow what you are trying to do? Seems overly complicated. What is the command that you use to run your script from the command line? Just add that to autostart. No need to mess with .Desktop etc.
Note that autostart must contain the following 2 lines. If not you will get the gray openbox screen.
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
Right click on the screen and select terminal then use nano to fix your autostart (get the desktop back).
loppefaaret
Wed Feb 26, 2020 2:09 am
I had the same effect as jlingley, when trying to autostart kodi on top of the desktop environment.
on a clean install of raspbian-buster-desktop set to autologin on desktop
wanting to autostart kodi on top of the desktop (main usage is kodi, but in case, user can exit kodi, and land on desktop)
if i:
mkdir -p ~.config/lxsession/LXDE-pi/
nano ~.config/lxsession/LXDE-pi/autostart
kodi
it will launch kodi just fine, but on exit, i am left on a black screen with a cursor (and it is not the framebuffer issue, where panels are under the black screen, and still active - it is just a complete black environment with nothing loaded, but mousecursor)
it seems when i add an entry to the previously mentioned autostart location, it will ignore the system wide settings under /etc/xdg/lxsession/LXDE-pi/autostart, which include:
@xscreensaver -no-splash
the solution (in my case, with kodi) is to add the lines from
to
along with commands i wish to launch
a little googling took me to this page
https://wiki.lxde.org/en/LXSession
where it is stated that older versions of lxsessions used to include autostart file from ~ but current versions will prioritize ~ and exclude /etc... if an autostart file is present under homedir... how this affects *.desktop files under ~/.config/autostart/ folder is for someone else to explore - im assuming this is the new way to autostart *.desktop programs now ?
gordon77
Wed Feb 26, 2020 3:01 pm
As I understand it if ~/.config/lxsession/LXDE-pi/autostart exists it will be run instead of /etc/xdg/lxsession/LXDE-pi/autostart
so if you had a ~/.config/lxsession/LXDE-pi/autostart then it was being run at startup, and presumably didn't have the lines in it you needed.
DE1CTL
Sun Mar 15, 2020 12:13 pm
Hi there,
I have edited the autostart file in /etc/xdg.... with:
sudo su
ifconfig wlan1 down
iwconfig wlan1 mode ad-hoc essid RPI_test channel 11
ifconfig wlan1 1.1.1.101 netmask 255.255.255.0
saved, rebooted --- wlan1 in managed mode :(
Please tell me what I did wrong and how to correct it.
Also I would like to start the iperf3 -s 1.1.1.101
Thank you,
Catalin
Return to “Beginners”
