Fabulierer
Solder a RJ Connector on a raspberry pi zero?
Wed Jun 26, 2019 2:44 pm
Hello!
I am not really new to the raspberry pi, however I have never soldered before.
I am planning on making an FTP server with a raspberry pi zero, however, the rp0 doesnt have a LAN connection. So I found this: https://www.conrad.de/de/p/rj45-steckve ... 97238.html
and now I'm wondering if I can just solder it on the GPIO pins, and it will work, or if I have to use certain GPIO pins?
Thanks a lot :)
mahjongg
Re: Solder a RJ Connector on a raspberry pi zero?
Wed Jun 26, 2019 3:20 pm
An Ethernet interface doesn't exist of just a connector! :geek: :mrgreen:
You need a whole lot of electronics in-between the zero and the RJ-jack.
the easiest solution, in hardware, would probably be an USB-to-Ethernet adapter.
Another solution would be a smart Ethernet adapter with an SPI interface, and a RPI driver for it.
Wed Jun 26, 2019 3:28 pm
Hello!
Thanks a lot :)
Something like this ?
https://www.ebay.co.uk/itm/Add-extra-1- ... 3101530663
Asus ChromeBox 3 Celeron is my other computer.
thagrol
Wed Jun 26, 2019 6:14 pm
Or this: https://raspi.tv/2015/ethernet-on-pi-ze ... on-your-pi
Don't expect much in the way of speed though.
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
alphanumeric
Wed Jun 26, 2019 7:36 pm
Plug and play and no soldering required.
https://shop.pimoroni.com/products/thre ... connector
Return to “Beginners”
