4k3or3et
Lasted Raspbian Buster, cannot rename user.
Mon Jun 24, 2019 9:38 pm
Hi guys
i cannot rename user on latest Raspbian Buster. while typing:
usermod -l newuser -d /home/newuser -m pi
i get:
usermod: user pi is currently used by process 1172
'ps -u pi' gives:
 1172 ?        00:00:00 systemd
 1175 ?        00:00:00 (sd-pam)
 1188 tty1     00:00:00 bash
I can kill 'systemd' and '(sd-pam)' but when i kill 'bash' process the 'systemd' and '(sd-pam)' comes back.
any clues how to successfully kill bash process?
Andyroo
Re: Lasted Raspbian Buster, cannot rename user.
Mon Jun 24, 2019 9:39 pm
Start in headless, sign on as root and see if that does it?
Edit: Previously it was always recommend that you just disable Pi and create a new user.
4k3or3et
Mon Jun 24, 2019 9:44 pm
My RPi is headless. VNC is disabled. Logged in straight as root. Also i disabled autologin. Any other clues guys?
HawaiianPi
Mon Jun 24, 2019 9:50 pm
... Previously it was always recommend that you just disable Pi and create a new user.
This ^
Just create a new user, add it to all the same groups as the pi user and disable (or delete) the pi user. That's what I've always done.
4k3or3et
Wed Jun 26, 2019 5:15 pm
Thanks guys.
Solution was to disable autostart in GUI of Raspberry Pi configuration. After reboot i could rename the user.
Return to “Beginners”
