Labhelp
How to make the GPIO connections more robust
Fri Jun 21, 2019 3:39 pm
Hey,
So I am currently working a relatively large machine and I have burnt the raspberry pi a 2 times too. It's my first time working with a pi but in the past month I think I understand it okayish. According to some forums and blogs I read, I think if I can get a more robust structure for all my electronic components, I will be able to save the pi and have it all connected to the machine so it runs smoothly and space efficiently.
So I have 2 stepper motors, 1 DC motor, a few buttons, a tachometer and 2 leds connected through the GPIO pins of the motor.
So is there a way I can make the GPIO pins more strongly secured by the pi?
And is there any way I can prevent the pi from getting burnt or fused?
Also, I was reading about the polyfuse, and wanted to know at what resistance should I know that it wont work again?
I appreciate any help
Thanks,
Dhruvi
gordon77
Re: How to make the GPIO connections more robust
Fri Jun 21, 2019 4:26 pm
The most secure method would be soldering the connections, but this might limit any future uses. The next would be a good quality 40pin socket and soldered wires.
This type of connector https://www.amazon.co.uk/2-54mm-40-Pin- ... B00R1LLM1M or maybe one with longer pins to solder to.
What is burning?
boyoh
Fri Jun 21, 2019 4:36 pm
First you must understand the Raspberry Pi
Is not Plug & Play, So more information is
Needed of how you are interfacing with
The Pi GPIO connections, a circuit drawing
Will be very helpful to give you some
Advice, Do not work on mains voltage
Unless you know what you are doing.
Regards BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
drgeoff
Fri Jun 21, 2019 5:38 pm
Solder wires to the underside of the board. It is easier than soldering to the long pins on the top side and doesn't "limit any future uses".
The GPIOs are electrically fragile and if abused can lead to fatal damage to the whole RPi. You must understand what the restrictions are and abide by them.
Quis custodiet ipsos custodes?
gordon77
Fri Jun 21, 2019 6:34 pm
One solution might be the pizero with no pins attached, then you can use the holes to solder the wires into.
LTolledo
Fri Jun 21, 2019 9:23 pm
My take on this is:
1. Make your own breakout-board that plugs into the RPi's GPIO header. On that breakout board you can have your connections soldered.
Also, you may want to incorporate some protection/isolation circuits on the breakout board....
2. If you dont like soldering, there are breakout boards that exposes the GPIO as screw-in terminals. You can connect your devices to those terminals.
something like:
GPIO breakout.jpg (8.19 KiB) Viewed 1370 times
Using either way you preserve RPi for possible "future use".
Some people be like:
boyoh
Sat Jun 22, 2019 8:14 am
You could make your own interface board
Using Vero board, as I have don, also fitted
Opto Isolators for signal isolating and
Voltage levelling, Just a Idea for you
Regards BoyOh,
Pi Board IF 010.jpg (59.8 KiB) Viewed 1339 times
JohnsUPS
Sat Jun 22, 2019 12:47 pm
As a general rule when I'm interfacing to the GPIO pins, I follow the pin with some sort of buffer, such as a transistor or inverter. The choice of buffer mainly depends on what is ultimately being driven. The buffer circuitry helps to protect the Pi in the case of an "oops" or line transient and can also serve to provide additional current if necessary.
hippy
Sat Jun 22, 2019 6:49 pm
I would recommend never soldering to a Pi directly if that can be avoided, especially if a number of connections are being made. It just makes it a royal pain if one needs to swap that Pi out for another.
I imagine Sod's Law has a special clause for that; do it any you will have to unsolder the lot, probably as soon as it's powered-up, do it with plug-in connectors and it will work forever.
I am not sure what the OP's issue with "robustness" is, mechanical, electrical, or both.
dl324
Sat Jun 22, 2019 7:08 pm
More secure than what? What are you currently doing?
Don't overload any outputs, operate inputs within specifications, don't short things.
You don't need a fuse if you don't make wiring mistakes.
boyoh
Sat Jun 22, 2019 10:06 pm
The polyfuse not only protects against wiring
Faults, will also protect against over current,
There is no man on this forum with a few years behind him who has never made a wiring mistake. I’ve made plenty in my time
Regards BoyOh
Return to “Beginners”
