yan
Pi3B temperature between 70-75 ° C
Fri Jun 14, 2019 6:49 pm
If the Pi3B develops a temperature of 70 - 75 ° C, and works for hours under these conditions, Can it cause damage to hardware?
Thanks.
epoch1970
Re: Pi3B temperature between 70-75 ° C
Fri Jun 14, 2019 6:53 pm
CPU temp or temp in the case?
CPU temp => no problem
Ambient temp => could cause problems w/ accessory cables, eg ethernet, USB.
yan
Fri Jun 14, 2019 7:01 pm
It's the CPU temp. Thanks!
Imperf3kt
Fri Jun 14, 2019 8:32 pm
It is pretty close to the recommended limit though. You might want to look into cooling it with a heatsink or similar, just so it doesn't throttle unexpectedly (to protect itself) and slow the system to a crawl.
55:55:44:44:4C
52:4C:52:42:41
