gabriel.rosseel
PHP Extension Intl missing
Sun Jun 09, 2019 7:04 am
Recently I installed ldapaddressbook 0.40 on my intranet website.
I get following error: The following PHP extension modules must be installed and enabled in order to use the address book: intl (internationalization Support)
can anyone heip me installing that Intl PHP extension module?
I use as OS: Raspbian Stretch, PHP version 5.6.30 and Apache Version 2.4.24
Thanks for any help.
Andyroo
Re: PHP Extension Intl missing
Sun Jun 09, 2019 8:19 pm
Not sure if you know of the PHP function guide?
This is the section of international language support https://www.php.net/manual/en/book.intl.php
I would make a backup first as these notes are a little behind your version!
fbe
Sun Jun 09, 2019 8:47 pm
Your PHP version is quite unusual for Raspbian Stretch. You need to figure out the package name, you have to install. Raspbian Stretch has php7.0 in its repository.
sudo apt install php-intl
would try to install the package php7.0-intl and most likely fails if a package php5.6 is installed...
gabriel.rosseel
Mon Jun 10, 2019 9:29 am
I tried sudo apt install php-intl as you mentioned but as you predicted it failed (I still run the previous PHP version)
I looked up how to uninstall a package: sudo apt-get --purge remove <package>
but I can't find the exact name of the package to uninstall
Can you help me please?
gabriel.rosseel
Mon Jun 10, 2019 10:55 am
with the command sudo apt list --installed I saw that besides php 5 also php 7 was installed.
but apparently php 5 is used.
also I run Webmin that says that all installed packages are up to date.
I hesitate to remove php 5 as I am afraid the other things might not work.
Am I right in doing so?
Return to “Beginners”
