Run bat file
Posted: Thu Jun 06, 2019 1:33 pm
by HF_ATL
I need to update a device from USB port connected to my Raspberry Pi 3 with Raspbian installed. The firmware update procedure runs only in Windows 7/10 platform and the way it works is by running a .bat file inside a folder. How can I do it with my Raspberry without having to connect the device to my Windows PC?
Thank you
Re: Run bat file
Posted: Thu Jun 06, 2019 1:39 pm
by RaTTuS
it probably will not work as it will want to run some windows or dos commands -
check the contents of the bat file to see what it does
Re: Run bat file
Posted: Thu Jun 06, 2019 1:49 pm
by HF_ATL
Thank you for the quick reply.
I'll edit the bat file and see if I can do the same commands in the terminal.
Re: Run bat file
Posted: Thu Jun 06, 2019 2:57 pm
by W. H. Heydt
After you find out what it does, you can probably write a shell script to do the same function on a Linux system.
