Cam output on Monitor without Latency
Posted: Wed Jun 05, 2019 8:57 am
by BenzW
My goal:
-Live Preview of the Rasperry Pi Camera (Without Network/Stream)
-Latency ~10ms
My hardware:
-Raspberry Pi 2
-Raspberry Pi Camera
Question:
Is is possible to achieve the goals with the mentioned hardware?
I tried die python "camera.start_preview" script, but the delay was way to high (~100ms).
Greetings! :D
Re: Cam output on Monitor without Latency
Posted: Wed Jun 05, 2019 9:06 am
by jamesh
raspivid is about as fast as you can get with regard to latency. Note though that at 30fps, each frame is 33ms, and I think there is one frame delay before it gets to the display. You could reduce the resolution, and up the frame rate to decrease latency.
by RaTTuS
use the rpi hdmi ?
Posted: Wed Jun 05, 2019 9:45 am
by BenzW
I tried it, but I get a strange phenomenon:
If I type "raspivid -t 10000 -w 400 -h 400 -fps 60 -vf -hf -o test1.h264" I get a perfect video with nearly no latency. But thats not exactly what I want.
This Command "raspivid -t 0 -w 400 -h 400 -fps 60 -vf -hf" just gives me the cam-output and doesn't save it. But there is more latency and the image in general looks very different.
Posted: Wed Jun 05, 2019 11:38 am
by jamesh
I just tried that, looked OK to me. No difference in the two commands that I could tell. What differences are you seeing?
