duckredbeard
Short blink/long pause LED with gpio zero
Tue Jun 04, 2019 2:27 am
I am using an LED to indicate that my security system program is running. I would like the LED to have a short blink (a bit longer than a flash) then a pause for 2-3 seconds. All I can find is
from gpiozero import LED
from signal import pause
red = LED(17)
red.blink()
pause()
Where the "red.blink(1)" would blink the LED one second on, one second off. How do I change each half of the cycle?
I have also tinkered with this:
while True:
    red.on()
    sleep(1)
    red.off()
    sleep(1)
and changed the values inside the () but I get lots of errors.
I just want a short on, long off cycle. Is there another library I should consider?
You can't know your limits until you exceed them.
pcmanbob
Re: Short blink/long pause LED with gpio zero
Tue Jun 04, 2019 6:13 am
There are several ways to do it using the code examples you posted , for a constantly flashing LED at say 0.5 second intervals then you could use
red = LED(17)
red.blink(0.5)
pause()
this gives 0.5 second flash constantly
for a 0.5 second flash once every 2 seconds then
from time import sleep
red = LED(17)
while True:
    red.on()
    sleep(0.5)
    red.off()
    sleep(2)
you could also do this using RPi.GPIO
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(17, GPIO.OUT)
while True:
	GPIO.output(17, GPIO.HIGH)
	time.sleep(0.5)
	GPIO.output(17, GPIO.LOW)
	time.sleep(2)
All code tested using python 3
duckredbeard
Tue Jun 04, 2019 9:31 am
I thought I had tried something like the
red = LED(17)
while True:
    red.on()
    sleep(0.5)
    red.off()
    sleep(2)
but I guess I didn't. Maybe I did the times in the red.on and red.off steps. I will try this again. Thanks!
B.Goode
Tue Jun 04, 2019 9:59 am
Reading the documentation for gpiozero shows that the ON and OFF times for LED.blink() can be specified separately: https://gpiozero.readthedocs.io/en/stab ... t.html#led
blink(on_time=1, off_time=1, n=None, background=True)
Make the device turn on and off repeatedly.
Parameters:
on_time (float) – Number of seconds on. Defaults to 1 second.
off_time (float) – Number of seconds off. Defaults to 1 second.
n (int or None) – Number of times to blink; None (the default) means forever.
background (bool) – If True (the default), start a background thread to continue blinking and return immediately. If False, only return when the blink is finished (warning: the default value of n will result in this method never returning).
davidcoton
Tue Jun 04, 2019 3:47 pm
pcmanbob wrote: for a 0.5 second flash once every 2 seconds then
red = LED(17)
while True:
    red.on()
    sleep(0.5)
    red.off()
    sleep(2)
[pedant]
That will give a 0.5s flash every 2.5s (0.5 on, 2.0 off)
For 0.5s flash every 2.0s use 0.5 on, 1.5 off
[/pedant]
But better to use B.Goode's suggestion:
red = LED(17)
red.blink(0.5, 1.5)
which will blink "forever" in a background thread, 0.5s on in every 2.0s
EDIT: proper attribution of quote
Signature retired
B.Goode
Tue Jun 04, 2019 3:55 pm
{Original content overtaken by events, removed.}
davidcoton
Tue Jun 04, 2019 4:02 pm
Deleted 'cos no longer relevant.
Signature retired
B.Goode
Tue Jun 04, 2019 4:07 pm
duckredbeard
Tue Jun 04, 2019 11:52 pm
Thanks everyone for their replies. I decided to go with
red = LED(17)
red.blink(0.08, 3)
and seems a good balance. I even had the on cycle shorter, but it doesn't bright up if you make the duration too short.
