glennford49
2 python script using single gpio pin
Sat Jun 01, 2019 10:44 am
will it be possible to use 2 scripts using only single pin
#first.py
import RPi.GPIO as GPIO
import time
pin = 8
GPIO.setmode(GPIO.BOARD)
GPIO.setup(pin,GPIO.OUT)
GPIO.output(pin,GPIO.HIGH)
GPIO.input(8)
can i use the 2nd script to read the pin 8 state?
how to read the pin 8 state?
im a newbie on raspberry pi hoping someone that can give me idea on this.
thanks
pcmanbob
Re: 2 python script using single gpio pin
Sat Jun 01, 2019 12:21 pm
Hi.
So you first program will be used for controlling the output pin.
#first.py
import time
pin = 8
Now in your second program you need to set the gpio pin in the same way, but with no GPIO.output, but now you can read its current state using a GPIO.input.
#second.py
import time
pin = 8
pin_state = GPIO.input(8)
your code was short and simple so it did not matter but please in future use code tags when posting code to preserve indentation.
Add [code] at the top
code goes here
and [/code] at the bottom.
glennford49
Wed Jun 05, 2019 2:31 pm
#second.py
import time
pin = 8
Python 3.5.3 (/usr/bin/python3)
>>> %Run first.py
>>> %Run second.py
second.py:6: RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
this is really my problem, thanks for your response
B.Goode
Wed Jun 05, 2019 3:43 pm
#second.py
import time
pin = 8
>>> %Run first.py
>>> %Run second.py
Why is it a "problem"?
Surely your deliberate intention is that the activity started by the first script should be detected by the second? If the Warning (note, not an error) troubles you, the message tells you what you can do about it.
glennford49
Thu Jun 06, 2019 10:02 am
#first.py
import time
pin = 8
GPIO.setwarnings(False) # avoiding future warnings
GPIO.output(pin,GPIO.HIGH) # set as high again without GPIO.cleanup()
is it just fine/safe to use GPIO.setwarnings(False) to avoid future warnings just incase if i set the same pin as high without GPIO.cleanup()?
thanks for the quick response above, its helps me a lot
pcmanbob
Thu Jun 06, 2019 10:09 am
You would normally only use GPIO.cleanup() at the end of your program as the last gpio command before exiting , it resets all gpio pin to the default state of input.
You can change the state of an output pin from high to low or low to high as many times as you wish within your program, if a pin is already set high then setting it high again has no affect , the same is try if a pin is set low and you set it low again.
what you can't do is have 2 programs attempting to set the same output pin high or low.
