howto redirect input to feh (slideshow program)
Posted: Sat May 25, 2019 5:54 am
by IpPsar01
Some help is needed on the following:
I would like to fork feh as a slideshow in the background and still be able to sent some keys to it (eg. 'n' for next picture or 'q' to quit).
So I created a pipe: mkfifo /tmp/cmdVideo
I exported DISPLAY=:0
and start: feh -Z -z -F -d -D10 -f /home/pi/newapp/AlleFotos </tmp/cmdVideo &
Via another shell I sent characters into the pipe:
To actually start feh: echo -n . > /tmp/cmdVideo
After that it starts showing pictures.
All my other characters don't arrive at feh. Eg.:
echo -n 'n' > /tmp/cmdVideo
echo -n 'q' > /tmp/cmdVideo
Feh just goes on showing pictures.
I have also tried to move the location of the '</tmp/cmdVideo' within the commandline but that did not help.
Obviously I am making a mistake here. Can someone help me in how to set this up correctly?
The same setup works fine for omxplayer .
Thanks in advance!
Re: howto redirect input to feh (slideshow program)
Posted: Fri Jun 28, 2019 12:51 pm
by IpPsar01
Anyone perhaps able to direct me in the right direction?
Or is this forum not the right place?
All help / direction is appreciated.
Thanks in advance!
Posted: Fri Jun 28, 2019 1:13 pm
by Andyroo
There is a post here on using C to do it https://stackoverflow.com/questions/223 ... nd-program
If you do not want to code, then have a look at the screen command and using that as per here and here
I use TMUX rather than screen - I’m now going to have to see if it will do the same or not :lol:
Posted: Tue Jul 02, 2019 4:25 pm
by IpPsar01
Thanks a lot Andyroo.
This gives me a direction that is very useful.
Posted: Thu Jul 04, 2019 8:32 pm
by IpPsar01
Thanks to the directions given... After a lot of trial and error I resolved it satisfactory enough.
The module that is called contains:
shellprog = subprocess.Popen(commando, shell=True, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE,bufsize=1, preexec_fn=os.setsid)
Where commando is my: feh -Z -F -d -D40 -f /home/pi/newapp/fpl
the 'shellprog' is returned.
The calling module contains:
shellprg = fotoplayer.FotoPlayer()
time.sleep(5)
os.killpg(shellprg.pid, signal.SIGUSR1)
time.sleep(5)
os.killpg(shellprg.pid, signal.SIGUSR2)
time.sleep(5)
os.killpg(shellprg.pid, signal.SIGTERM)
I can not get feh to use the characters I sent in a pipe. It will only use the characters typed into the console keyboard if feh is havig the console focus.
All other methods I tried did not give the result I needed ( echo to /proc/XYZ/fd/0, use mkfifo pipe, ...)
Similar principle works better for omxplayer since omxplayer actually uses the characters I write into the pipe: shellprg.stdin.write("q")
