me_ganesh
No module named flask after installing flask
Fri May 24, 2019 9:22 am
hello!
I am currently working on Flask and uWSGI, honestly iam a complete beginner to flask.
I created a virtual environment in /var/www/lab_app/ named as 'venv'
I installed flask using the command
sudo pip install flask
I created a python file in lab_app folder named hello.py which contains the following code
from flask import Flask
app = Flask(__name__)
@app.route("/")
def hello():
        return "Hello World!"
if __name__ == "__main__":
        app.run(host='0.0.0.0',port=8080)
and when I try to execute the python file using
python hello.py
it gives me the following error :
installed flask.png (247.47 KiB) Viewed 389 times
croston
Re: No module named flask after installing flask
Fri May 24, 2019 9:31 am
By using 'sudo' on the pip install command, you have installed Flask globally on your pi, not in your virtual environment. Just install it in your venv by not using sudo.
Fri May 24, 2019 10:03 am
You've installed flask for python2 you need to use sudo pip3 install ... to get it for python3 (and all users).
me_ganesh
Fri May 24, 2019 10:05 am
I uninstalled flask globally using
sudo pip uninstall flask
and then in my virtual environment I tried to install flask using
pip install flask
It gives me this error
me_ganesh
Fri May 24, 2019 10:12 am
I am using python 2
Fri May 24, 2019 10:13 am
Your original errors have python3 written all over it. Stop using python2 for new code. Write everything new with python3.
me_ganesh
Fri May 24, 2019 10:40 am
sir, can you please explain this to me?
when I execute
python --version
it gives out
Python 2.7.3
when I execute
flask  --version
it gives out python version as 3.5.3
Fri May 24, 2019 11:07 am
What do you get when you enter
python3 --version
Signature is on holiday.
me_ganesh
Fri May 24, 2019 11:15 am
how can there be two different versions of python?
I even deactivated my virtual environment
jojo777
Fri May 24, 2019 11:21 am
sudo apt-get update
sudo apt-get install python3-pip
pip3 install --upgrade pip
pip3 install flask
python3 hello.py
Ave Cezar
Andyroo
Fri May 24, 2019 11:55 am
That is very normal (you should see some Macs). Both Python 2 and 3 are included by default on the Pi builds and modules get loaded into the release directory structure. e.g. V2 structure and it’s equivalent in your own projects at http://as.ynchrono.us/2007/12/filesyste ... ct_21.html. Note this can change depending on the platform you are on.
The command python is a link to the version 2 command so to access v3 you have to use python3 at the command line.
GUI editors (Thonny / Idle etc) can have different versions of Python used by default and Visual Code from MS lets you change versions from the editor.
If this sounds like a mess it is and trips lots of folk up lots of times BUT there is so much legacy code out there that removing Python2 is very hard to do.
From what I am seeing it’s best to either develop in Python 3 only (and use pip3 where needed) or live totally in a virtual environment where you can dictate how and where modules are loaded.
me_ganesh
Fri May 24, 2019 12:36 pm
Why am I not able to install any module using pip in my virtual environment?
Is it because I have created my virtual environment in /var/ directory?
Andyroo
Fri May 24, 2019 12:51 pm
Could be or it could be that you used sudo to create the environment.
I’ve no Pi handy at the mo and feeling yuck so I cannot check for you :oops: but you could try changing the ownership of all objects / folders to pi:pi and see if that helps.
Not sure about using /var - I thought that was more system than user (but me new to bits of Linux :lol: ) http://www.linfo.org/var.html
DirkS
Fri May 24, 2019 4:54 pm
who is the owner of /var/www ?
Often it's a specific user created for the web server and there could be a problem trying to access it with user 'pi'
Andyroo
Fri May 24, 2019 5:03 pm
Missed that - by default on every version of Raspbian I've used it has been www-data and not Pi.
Flask does not care about /var/www - it can serve pages from anywhere in the system if it has access to them and is covered here with pictures (OK - the daft robot and rocket at the top can be ignored)
