WillWam
OctaPi - Python Pickle Error
Mon May 20, 2019 10:10 pm
I'm currently figuring out how to make an "OctaPi", but on step 8 of this tutorial (https://projects.raspberrypi.org/en/pro ... n-octapi/8) I get the following error from Dispy when I try to run compute.py:
Dispy - Ignoring node 192.168.1.249 (ValueError: unsupported pickle protocol 4)
I've been trying to fix this for days. Thanks for your help :D
Andyroo
Re: OctaPi - Python Pickle Error
Mon May 20, 2019 10:23 pm
Are you running under Python 2?
Python 2 does not support protocol 4 so you would need to use Python 3.4 or above. Four is documented here
You can try your version of Python 3 on the Pi by using the command line
python3 ––version
and check it’s 3.4 or above.
Andyroo
Tue May 21, 2019 8:37 am
Any reason you are on Python 3.7? My boxes are a bit out of date but only on 3.5.3
What does the software say to run it on?
WillWam
Tue May 21, 2019 12:18 pm
The tutorial just says 3, (hint from "python3 compute.py", etc.). But since it doesn't say what version, I just did this:
sudo apt-get install python3-dev libffi-dev libssl-dev -y
wget https://www.python.org/ftp/python/3.7.3 ... 7.3.tar.xz
tar xJf Python-3.7.3.tar.xz
cd Python-3.7.3
./configure
make
sudo make install
sudo pip3 install --upgrade pip
B.Goode
Tue May 21, 2019 1:16 pm
cd Python-3.7.3
./configure
make
sudo make install
I have never used this tutorial, but I wonder if you might have navigated into uncharted waters not considered by the authors at the Raspberry Pi Foundation when they did the documentation?
In the sections about setting up an OctaPi client and an OctaPi server it says "On your micro SD card, install the latest version of Raspbian". And if you do that today the version of Python3 that is installed will be 3.5.3 -
[email protected]:~ $ apt-cache policy python3
python3:
  Installed: 3.5.3-1
  Candidate: 3.5.3-1
  Version table:
 *** 3.5.3-1 500
        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
        100 /var/lib/dpkg/status
[email protected]:~ $ python3 --version
Python 3.5.3
Just curious, but not with any inside knowledge, as to whether advancing the version of Python3 beyond that documented might be the source of the problem?
A simple comparison with python v3.5.3 as the interpreter would be interesting...
ejolson
Tue May 21, 2019 8:12 pm
That's a nice tutorial, except for the pickle.
I have put together an alternate set of instructions for building a Pi cluster here using a more standard approach based on Slurm and MPI. If you continue to have trouble, I recommend trying to setup Slurm and MPI because those systems also work with Python.
WillWam
Tue May 21, 2019 9:25 pm
I would except I've worked through MPI, not a huge fan, and I've gone through 8 different ways of doing this, and this is the most promising. I have to stick with this one
WillWam
Tue May 21, 2019 9:27 pm
cd Python-3.7.3
./configure
make
sudo make install
python3:
  Installed: 3.5.3-1
  Candidate: 3.5.3-1
  Version table:
 *** 3.5.3-1 500
Python 3.5.3
'python3' wasn't a command on my fresh version of Raspbian Lite
Andyroo
Tue May 21, 2019 9:34 pm
Strange, I’ve built two Pi Zeros and one 3B+ since the new version of Lite came out and all are running Python3 fine.
I would be tempted to create a new SD card and let’s try to work out why you cannot see Python 3...
B.Goode
Tue May 21, 2019 10:21 pm
I have been trying to help on the premise that you were following the Raspberry Pi Foundation documentation referenced in your initial post.
Since that is not the case I will withdraw from the discussion.
WillWam
Wed May 22, 2019 9:20 pm
I got python 3.5 to work, but still getting the error
Andyroo
Thu May 23, 2019 12:17 am
Which error?
