IBrokeIt
Synaptic wont work on new install
Mon May 20, 2019 10:54 am
I installed Raspbian Lite and XFCE on my new Pi3B+ earlier by following this guide.https://www.raspberrypi.org/forums/view ... p?p=890408
I made a panel, changed the desktop picture, installed VLC and then installed Synaptic by typing
sudo apt-get install synaptic
Thats all I have done.
When I click Synaptic's icon on the start menu, desktop, or application finder nothing happens.
When I type
synaptic-pkexec
into the terminal I get:
===AUTHENTICATING FOR com.ubuntu.pkexec.synaptic===
Authentication is required to run the Synaptic Package Manager
Authenticating as: root
Password:
If I type "raspberry" as the password I get an authentication failure. I dont know of any other passwords that should be on here.
What did I do wrong?
How do I get Synaptic to work?
Will I ever be any good at anything?
mattmiller
Re: Synaptic wont work on new install
Mon May 20, 2019 11:10 am
does
sudo synaptic-pkexec
get you anywhere?
klricks
Mon May 20, 2019 12:52 pm
When I type
synaptic-pkexec
Password:
Possibly because you have a non standard install, Synaptic is expecting the root password. By default the root password is not set in Raspbian but can be set with:
sudo passwd root
Try that.
IBrokeIt
Mon May 20, 2019 9:00 pm
Thanks for the replies.
made it run and didnt ask for a password.
I feel a little dumb for not trying to sudo it before, but I was sleepy, this is my first nonstandard install, and Ive only had this pi thingy a couple of days.
Is it weird that using sudo doesnt ask for a password? Is the user 'Pi' different from a regular user or something? Should I be extra careful with 'Pi' like it's root and I could screw everything up?
When I click Synaptic's shortcut in a regular distro does it sudo it automatically? Ive never had to do this after getting Synaptic on anything else. I'd just click the icon and it would work.
I'm a helpless n00b. Please don't eat me.
rpdom
Tue May 21, 2019 6:53 am
It's not that weird, it's set in the file /etc/sudoers.d/010_pi_nopasswd
pi ALL=(ALL) NOPASSWD: ALL
If you remove or disable (rename with a ~ or . on the end) that file you will be prompted for the pi password (which hopefully you have changed from the default).
Other than being wary of using sudo in general, "pi" is just a standard user with membership of certain groups, like gpio and sudo.
Unreadable squiggle
Return to “Beginners”
