afgoody
Generally accepted standard process to install Node.js and NPM
Sat May 18, 2019 3:33 pm
I'm rebuilding my RPi 3 and can't seem to get Node.js and NPM installed properly. As I research, I find many different processes, command syntax, and recommendations (e.g. using Node Version Manager, which folder to extract the files into, etc.).
I followed these instructions (https://www.battlehillmedia.com/install ... erry-pi-3/) to attempt to completely remove all Node.js and NPM. It seemed to work (see below).
Is there a generally accepted standard process to install Node.js and NPM?
[email protected]:~ $ node -v
v8.11.1
[email protected]:~ $ npm -v
-bash: npm: command not found
[email protected]:~ $ sudo apt remove nodered -y
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libc-ares2 libhttp-parser2.8 libuv1 nodejs nodejs-doc
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
nodered
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 60.1 MB disk space will be freed.
(Reading database ... 132983 files and directories currently installed.)
Removing nodered (0.20.5) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for gnome-menus (3.13.3-9) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
[email protected]:~ $ sudo apt remove node nodejs nodejs-legacy -y
Package 'node' is not installed, so not removed
Package 'nodejs-legacy' is not installed, so not removed
libc-ares2 libhttp-parser2.8 libuv1 nodejs-doc
nodejs
After this operation, 15.8 MB disk space will be freed.
(Reading database ... 126220 files and directories currently installed.)
Removing nodejs (8.11.1~dfsg-2~bpo9+1) ...
Processing triggers for man-db (2.7.6.1-2) ...
[email protected]:~ $ sudo apt remove npm -y
Package 'npm' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
-bash: /usr/bin/node: No such file or directory
[email protected]:~ $ sudo apt remove --purge node
Return to “Beginners”
