Finding small monitors
Posted: Sun Apr 28, 2019 8:54 am
by Finch47
Hey guys, I'm new to the use of raspberrypis, and am currently setting up a KaliPi so i do pen testing on my own systems. My set up went well but now im lacking a monitor. I found the one linked in the post but looking for other suggestions. Any help in finding a monitor is appreciated.
https://www.amazon.com/Raspberry-320x48 ... 0173&psc=1
Re: Finding small monitors
Posted: Sun Apr 28, 2019 11:18 am
by B.Goode
Welcome to the Raspberry Pi forums.
Pretty much any HDMI monitor will work with an RPi board.
Or the Raspberry Pi Foundation have their own display with its own dedicated connection: https://www.raspberrypi.org/products/ra ... h-display/
What are the constraints on your choice that makes this difficult?
Posted: Sun Apr 28, 2019 11:21 am
by k-pi
If you want a 'normal' small monitor, take a look at Eyoyo, I have 3 of them in different sizes.
Posted: Sun Apr 28, 2019 5:08 pm
by Finch47
Biggest contraint in portability and money. Like I said in my first post, im using thia as a mobile pen test machine.
Posted: Mon Apr 29, 2019 1:34 am
by knute
Waveshare makes some nice little screens. I've got a touch screen that is the same dimensions as the Pi and works great. Guess it kind of depends on what you want to show.
What is pen testing?
Posted: Mon Apr 29, 2019 7:32 am
by DougieLawson
Pen[extraction] testing is ethical hacking where a client gives you an id on a system with the privileges of a regular or restricted user. The goal is to see if you can elevate those privileges to a superuser or access resources that should be protected.
It's a way to beat your head against a wall without the physical pain. It's incredibly frustrating trying things and getting nowhere. The likelihood of finding a backdoor on a well secured system is very low. The systems I've tested have both been done after a full scale security audit and remedial changes.
On the ones I've done on mainframe database systems I've produced violations that have tripped the clients trip-wires and revoked my access to the system.
Failing to break a system is just as satisfying as breaking in.
Posted: Mon Apr 29, 2019 9:23 pm
by knute
Thanks!
