RDK
Python vs Python 3 - can't find module??
Mon Apr 08, 2019 3:24 pm
I have a problem with Python 3 not finding a module library, but Python 2.7 does. Here is a VERY simple program:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
from pyModbusTCP.client import ModbusClient
print("hello world")
Below you can see back to back runs of this program only switching from python to Python3.
me@V2B_Stretch_Test:~ $ python /mnt/usbdrive/pgms/modbus/PrintHi.py
hello world
me@V2B_Stretch_Test:~ $ python3 /mnt/usbdrive/pgms/modbus/PrintHi.py
File "/mnt/usbdrive/pgms/modbus/PrintHi.py", line 4, in <module>
ImportError: No module named 'pyModbusTCP'
I suspect I have a location or permissions issue, but my expertise stops before this. Can someone help?....RDK
pcmanbob
Re: Python vs Python 3 - can't find module??
Mon Apr 08, 2019 3:36 pm
Did you install it just for python ( ie python 2 )
sudo pip install pyModbusTCP
If so you probably need to run the install again this time for python 3
sudo pip3 install pyModbusTCP
B.Goode
Mon Apr 08, 2019 3:37 pm
Human beings can see that python(2) and Python3 are pretty much the same thing.
But from the viewpoint of the Raspbian Operating System they are two completely different languages, mythically named Adder and Anaconda.
A library installed for 'Adder' will not be recognised or imported by 'Anaconda', or vice-versa.
It is the same for Python2 and Python3...
RDK
Mon Apr 08, 2019 4:26 pm
OK, well, I in fact installed it from the GIT
sudo git clone https://github.com/sourceperl/pyModbusTCP.git
Now should I reinstall as you propose? How do I remove the clone installed library?
Thinking about it I have many libraries which I installed via the clone process, for example RTL_433. Is there a general fix so that both can access the library?.....RDK
B.Goode
Mon Apr 08, 2019 5:43 pm
So, reading the documentation for that Repository...
You have chosen not to use the easy way...
Instead you have probably done:
cd pyModbusTCP
sudo python setup.py install
So 'the simplest thing that might work' is, still in that same directory:
sudo python3 setup.py install
Since the developer/maintainer says "The module is currently test on Python 2.6, 2.7, 3.2, 3.3, 3.4 and 3.5.", if that doesn't work maybe ask for advice via the Issues page for the Repository.
