Error when sudo apt-get dist-upgrade of Pi B+
Posted: Tue Apr 02, 2019 5:31 am
by RDK
Yesterday I decided to update this Pi B+ currently running Jessie. I ran the
  • sudo apt-get update
    sudo apt-get upgrade
The first two completed normally, but the last sudo apt-get dist-upgrade ended with an error
Setting up bluez (5.23-2+rpi2) ...
Job for bluetooth.service failed. See 'systemctl status bluetooth.service' and 'journalctl -xn' for details.
invoke-rc.d: initscript bluetooth, action "start" failed.
dpkg: error processing package bluez (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of pi-bluetooth:
 pi-bluetooth depends on bluez; however:
  Package bluez is not configured yet.
dpkg: error processing package pi-bluetooth (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of pulseaudio-module-bluetooth:
 pulseaudio-module-bluetooth depends on bluez (>= 4.40); however:
dpkg: error processing package pulseaudio-module-bluetooth (--configure):
Errors were encountered while processing:
 bluez
 pi-bluetooth
E: Sub-process /usr/bin/dpkg returned an error code (1)
What should I do now? I'm guessing that it has to do with the fact that the B+ does not have Bluetooth? Has this left this PI in a unstable state? Did the dist-upgrade completely or partially fail? ….RDK
Re: Error when sudo apt-get dist-upgrade of Pi B+
Posted: Tue Apr 02, 2019 8:37 am
by fruitoftheloom
 bluez
 pi-bluetooth
FYI Raspbian Jessie went end of life August 2017 !
Posted: Tue Apr 02, 2019 9:28 am
by pcmanbob
In answer to your question all it has done is left the blue tooth packages un-configured because there is no blue tooth device, it should not affect the operation of your pi.
I think you would see a similar error message if you were running raspbian stretch because it would not find a blue tooth device either.
Posted: Tue Apr 02, 2019 4:46 pm
by RDK
Yes, I just finished upgrading to Stretch via this reference (https://www.datenreise.de/en/raspberry- ... o-stretch/).
And, yes, I got basically the same errors from the
and the
sudo apt-get autoremove commands
Is there a way to tell it not to look for the Bluetooth functionality?...RDK
Posted: Tue Apr 02, 2019 7:12 pm
by rpdom
The package configuration shouldn't fail due to lack of bluetooth devices. That is a bug of some sort. I suspect some package changes between Stretch and Jessie have caused this.
Posted: Fri Apr 05, 2019 5:48 am
by RDK
Note: Pi B+
Continuing the saga from my previous posts: I found a Bluetooth dongle and reran these commands:
sudo apt-get update
The last one took forever (5+ hours), but finished with no errors.
However, now when I boot-up, I get this message:
failed to start dhcpcd on all interfaces
It does get an IP address for eth0 but not for the wifi interface. Before the upgrade from Jessie to Stretch both interfaces worked correctly. Both are supposed to get DHCP supplied addresses.
What do I need to do to get it working again?.....RDK
Posted: Fri Apr 05, 2019 7:18 am
by fruitoftheloom
Note: Pi B+
sudo apt-get update
It clearly states in the Raspbian Stretch Blog that going from Jessie to Stretch is not recommended:
https://www.raspberrypi.org/blog/raspbian-stretch/
Just use your back up to go back to Jessie and grab another SD Card and start with a fresh install of Stretch:
Going from Stretch to Buster in the summer should have less foibles..........
Posted: Fri Apr 05, 2019 9:28 am
by davidcoton
Note: Pi B+
dist-upgrade by itself does not move from Jessie to Stretch. Did you follow the RPF published procedure and update your sources list?
[Note as stated above, upgrade from Jessie to Stretch is not guaranteed to work.]
If you have successfully upgraded, what is now in wpa-supplicant? Under Stretch you need to set your country before WiFi will work.
Posted: Sat Apr 06, 2019 3:51 pm
by RDK
Not sure why, but after two reboots it is now working correctly....RDK
