RDK
Get a new folder in the the PATH
Mon Apr 01, 2019 3:03 pm
I have installed some programs in /usr/pgms/MyStuff which I would like to run from the command line without first cd-ing the that folder or including the full path on the program command. In addition I want those programs to be available to other users on this Pi.
For example, I want to run test.py from the command line. It fails to find the program unless I first run the
cd /usr/pgms/MyStuff
command.
I'm sure there is an easy way since all of the apt-get installed programs are universally available and those via cloning from a GIT site are also universally available to all users. I've Googled it and am not finding anything useful to this novice user.
Can someone help?....RDK
Re: Get a new folder in the the PATH
Mon Apr 01, 2019 3:09 pm
One of the traditional places to put your own programs in Debian based systems is /usr/local/bin. That directory is already in the PATH.
Unreadable squiggle
RDK
Mon Apr 01, 2019 3:38 pm
OK, but if I want to keep them all together in the current directory. Is there a way, as per my original post?....RDK
scotty101
Mon Apr 01, 2019 3:43 pm
RDK
Mon Apr 01, 2019 4:16 pm
OK, I saw that reference, but mostly it confused me!! There are/were too many answers and they often seemed to be in conflict. Mostly I want one simple answer. But, I will go back for another look....ROK
k-pi
Mon Apr 01, 2019 7:01 pm
export PATH=$PATH:/path/to/your/dir
That should attach it to your running session.
(It should also work if you add it to the end of your .profile file.)
RDK
Tue Apr 02, 2019 5:20 am
OK, I edited /etc/profile and when I echo $PATH it shows the change. However, I not sure this will affect other users on the Pi....RDK
