https://botland.com.pl/pl/moduly-i-zest ... b-ram.html
https://botland.com.pl/pl/wyswietlacze- ... 2zero.html
can i use these to connect it
https://botland.com.pl/pl/nowosci/8769- ... -zero.html
- default_user8
Re: I need somebody to check if these parts are compatible.
You're joking right?
Two heads are better than one, unless one's a goat head.
Well... The display claims to be for--among others--the Pi0. Yes, you'll need so solder in a 2x20 0.1" header to connect the two. Or you can buy a Pi0WH and the headers will already be soldered on the board.
As ridiculously inane as it is for those of use who know, it's not so much so for those who don't.
As such, no, I do not believe they're joking.
My stepfather, for instance, still has trouble knowing whether he can charge his mobile phone with its supplied usb cable, in certain usb ports, no matter how many times I tell him the "u" is short for "universal"
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
52:4C:52:42:41
- default_user8
I'm not trying to be insensitive to anyone's request, however this one seems a little to easy for anyone to figure out. Since the first link is for a pi zero, the second link is for a lcd that the ad states is for a pi zero and shows the screen attached to a pi zero, and the third link is for a GPIO header that the ad states is for a pi zero. So yes i would say these parts are compatible.Imperf3kt wrote: ↑Sat Mar 30, 2019 3:36 amAs ridiculously inane as it is for those of use who know, it's not so much so for those who don't.
Well it is his/her first post.
Mind you Zero's are not the best place to start in Pi world.
And the answer to the question is "yes"
I'm dancing on Rainbows.
Just wanted to be sure.
- default_user8
No problem, sorry if i came off as a jackass, don't let that deter you from seeking advice here on this forum. I really don't mind helping people since I've received so much help here I try to give back. Good luck and have fun with your project!
