Inertia94
Raspberry Pi, Ultrasonic Sensor and mini Breadboard
Thu Mar 21, 2019 2:24 pm
Hi to everyone.
I'm new to family of Raspberry Pi and I want to connect a hc-sr04 to raspberry pi with a mini breadboard. Is it possible to connect it, because all the tutorials are using a normal breadboard.
Thanks in advance.
Andyroo
Re: Raspberry Pi, Ultrasonic Sensor and mini Breadboard
Thu Mar 21, 2019 3:46 pm
Normally the mini breadboards I have do not have power rails running along the edges but only have column pins.
If its like these then you have no issues - just be careful as to what connects to what (as normal).
This may be of help if folk are new to the mini breadboards https://learn.pimoroni.com/tutorial/170 ... breadboard
Sorry for the big pic from RasPiO - its 10 times life size I think and Google have taken the 'small' off the search tool :lol:
edited: To shrink picture a bit
Forris
Raspberry Pi Certified Educator
Thu Mar 21, 2019 3:49 pm
Yep. I use mini breadboards for these. The wiring is the same. Here's a site I found that has an image of the breadboard layout for you.
http://www.makerspace-uk.co.uk/hc-sr04- ... ic-sensor/
mattmiller
Thu Mar 21, 2019 3:57 pm
JFI - You can now get Pi friendly ultrasonics that don't need resistors and work from 3.3V supply
I highly recommend using them instead of the old 5V ones
example of a 3.3V one
(note no metal can in-between the sensors)
https://www.ebay.com/c/564102643
Inertia94
Fri Mar 22, 2019 11:49 am
Thanks for your quick and efficient help! I did it and it works awesome!
Costas
Forris
Fri Mar 22, 2019 3:02 pm
JFI, there is now a 3.3V version of these available which doesn't need the resistor divider to lower the voltage. It can just be connected straight to the Pi.
https://shop.4tronix.co.uk/products/hc- ... nce-sensor
