Jawloms
Control other than via GPIO
Sat Mar 16, 2019 8:14 pm
I have a 4" touch screen on my Pi connected to all the GPIO pins. I want my Pi to interact with a Micro:BIT, sending and receiving info. The obvious way is via the GPIOs. Is there another way I can make the two talk?
Thank you
Stuart
B.Goode
Re: Control other than via GPIO
Sat Mar 16, 2019 8:38 pm
Depending on what unspecified model of RPi you are using, maybe Bluetooth?
Andyroo
Sat Mar 16, 2019 8:39 pm
You should find you screen only uses a small number of the pins - often power, spi and a couple of control lines. It’s normally just the header that’s taking up the rest of the pins on the header.
Saying that though, you can use Bluetooth to link the two together.
Jawloms
Sat Mar 16, 2019 8:45 pm
Brilliant, thanks both.
