Spalunkeldusch
run python script on boot issue
Fri Mar 15, 2019 10:42 pm
I have a python script that displays text on my i2c OLED screen connected to the Pi. It asks to attach the RFID card to the reader. After the card is attached the screen displays the card ID and other data. When I try to run this script via default raspbian text editor - it doesn't work. I get a missing library error or something, however, when I run in it in a terminal with sudo python scriptxx.py it works as intended.
What I want to do is to run that script automatically when i plug my raspberry to a power source. I have tried using this guide's https://www.dexterindustries.com/howto/ ... t-startup/ options: rc.local; .bashrc; crontab; however it was not able to produce the result I wanted. Usually, after I execute everything as shown in mentioned tutorial and reboot the raspberry, my i2c OLED screen gives me random pixels whole over the screen. Is it because it is unable to run the script using text editor like I have mentioned before?
Is there a way to just run my script on boot without having to manually start it every time my Pi boots to prevent any errors?
If so, could you please give me a step by step guidance?
Much appreciated!
thagrol
Re: run python script on boot issue
Sat Mar 16, 2019 12:50 pm
What libraries are you importing and where have they been installed?
You may find that setting the current working directory before calling your script (or as the first thing your script does - see the os module) cures the problem.
For example, start your script with:
#!/usrbin/env python
import os
os.chdir('/path/to/directory_containing_script')
# rest of code goes here
Should work with python 3 too
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
Spalunkeldusch
Sat Mar 16, 2019 2:39 pm
import os
Thank you for you answer.
I am currently using these libraries. They are located in /home/pi/ i assume, and the project script is located in /home/pi/Downloads, is that an issue?
#!/usr/bin/env python ---just added this after reading your answer.
import os
os.chdir('/home/pi/Downloads/') ---just added this after reading your answer.
import RPi.GPIO as GPIO
import sys
sys.path.append('/home/pi/MFRC522-python')
import SimpleMFRC522
import datetime
import requests
import time
import Adafruit_GPIO.SPI as SPI
import Adafruit_SSD1306
from PIL import Image
from PIL import ImageDraw
from PIL import ImageFont
import subprocess
When I try to run the script using "Thonny" editor I get the following error:
File "/home/pi/Downloads/script.py", line 12, in <module>
ImportError: No module named 'Adafruit_GPIO'
If I run it via terminal, by going to script location -> cd Downloads; then -> sudo python script.py ----- it works as intended.
I have tried to add my script location to /etc/rc.local; I have added it before 'exit 0' command and my line was
/home/pi/Downloads/script.py &
& added at the end of the line since my script loops over and over again. I have also tried making my script executable with chmod +x script.py - didn't work as well. Also tried to type in rc.local line like this: sudo python /home/pi/Downloads/script.py & - didn't work as well.
after I reboot the Pi I always get this image on the OLED itself:
What I have also noticed, that after I reboot my Pi and launch the script manually via terminal - it launches properly - display is showing what is intended to be shown, however it doesnt react to my RFID card attachment to the reader. After I attach the card to the reader I should get a response on the screen with details. However it just displays the main screen. After I restart the script manually - it starts working properly. Weird :/
Anything you could help with?
thagrol
Sat Mar 16, 2019 5:35 pm
That's a pretty clear indication of what's wrong. At least when running from thonny. Unfortunately I don't use it but be aware that thonny has a built in python engine that it uses in preference to the system one.
Thonny also uses python 3 not python 2 (aka python), that can make a difference in which version of a library is needed.
When you ran thonny what was the current working directory? If youu started it via the desktop menu it's unlikely that it is "/home/pi/Downloads" so it can't find the library. Unless you've done a formal install of the library it won't be anywhere on the default $PYTHONPATH
because the current working directory is the one that contains both the script and the library
[/quote]
First thing to do is to change that to the one below. As things are you're losing all output and error message from your script. The failure may very well be for a different reason.
 python /home/pi/Downloads/script.py > /tmp/script.log 2>&1 &
"sudo" is not needed as rc.local is already run by root. Once that changes has been amde, reboot and look at the contents of /tmp/script.log to see what error/exception is actually occuring.
Not with those last items. I don't have your hardware. When you launch it manually did you cd to its directory first or just run, say,
A couple of other points:
  • As I mentioned above, thonny runs python3 "python" runs your code under python 2. There are differences but I don't know if they'll be critical to your code.
  • When calling your script using "python ..." the shebang (#!...) isn't needed, nor is execute permission.
  • The user running the python interpreter must have read permission on your code and any custom libraries you're using.
klricks
Sat Mar 16, 2019 7:23 pm
If the script needs to be run as user pi then try this in rc.local
sudo -u pi python /home/pi/Downloads/script.py &
thagrol
Sat Mar 16, 2019 8:19 pm
Or skip rc.local entirely and put it in the pi user's crontab.
Either way, until we have the actual error message you're getting when starting your script at boot there ain't a whole lot more that we can do.
Spalunkeldusch
Sun Mar 17, 2019 6:55 pm
I have managed to bypass the library error by moving to library directory and running
sudo python3 setup.py install
Now, I have it running properly without errors even with Thonny.
Now, I have executed two commands:
sudo crontab -e
At the end of crontab window I have typed in:
@reboot /home/pi/Adafruit_Python_SSD1306/examples/script.py & > /home/pi/log.txt
After reboot, the script starts properly on my OLED, however it does not respont to my RFID reader like I have mentioned previously. This happened before, when I restarted the Pi, started the script via Terminal, it started properly however was not functional. Then I just had to CTRL+C to stop it and launch it again and everything started working as inteded.
The log file I have generated is empty (?).
Anything?
thagrol
Sun Mar 17, 2019 8:43 pm
Sorry, no suggestions on that. I don't have the hardware or your code.
That could be correct. I can't say for certain without seeing the code. If there are no "print" statements there won't be anything written to stdout. Be aware that ">" only redirects stdout. As error messages go to stderr any that occur won't be captured. If you want to capture any error messages change your crontab entry to
@reboot /home/pi/Adafruit_Python_SSD1306/examples/script.py & > /home/pi/log.txt 2>&1
That will capture any error text taht occurs into the same log file.
will0thewisp
Wed May 20, 2020 2:54 pm
This...
import os
...made my week.
Thank You!!!!
