Page 1 of 2
Sharing an existing folder using Samba
Posted: Wed Mar 13, 2019 3:16 pm
by Thoughtfission
Hello fellow Pi folk,
I was wondering if an Uber Noob could get some help here?
I recently purchased a 3b+ to act as a family file server. I am a unix admin from decades ago and have pretty much forgotten everything when it comes to any variant of Unix.
I was able to install Stretch, Samba and Webmin. Hooray!
The thing I am having trouble with is sharing an existing folder using Samba.
I have a HD connected to the Pi through a usb port. The partitions on the drive are formatted as ext4. There are existing folders and files on these partitions.
How to I go about sharing one of these existing folders using Samba? Everything I try just seems to create an empty directory (home directory?) that is shared. Nothing in it.
Sincere apologies if I am posting this in the wrong place.
Thanks!
Re: Sharing an existing folder using Samba
Posted: Wed Mar 13, 2019 4:28 pm
by jamesh
Posted: Wed Mar 13, 2019 10:27 pm
by hortimech
Probably not, for the following reasons:
It shows this as a share:
[share]
    path = /home/pi/shared
    available = yes
    valid users = pi
    read only = no
    browsable = yes
    public = yes
    writable = yes
Lets examine that.
'available = yes' and 'browsable = yes' are default settings, so do not need to be set.
'public = yes' is a synonym for 'guest ok = yes'
'read only = no' is a synonym for 'writable = yes', so you do not need both.
Now we come to the big one, there is this: 'valid users = pi'
This means that the only user that can connect is 'pi', but there is also supposed to be 'guest' access, this will never work
So, if you want only named users to connect, you need something like this:
[share]
    valid users = pi
    read only = no
If you want only authenticated users to connect, you need to something like this:
[share]
    read only = no
If you want Authenticated users and guest access, you need something like this:
[share]
    read only = no
    guest ok = yes
You cannot have guest access AND only allow named users access.
Posted: Thu Mar 14, 2019 9:46 am
by jamesh
[share]
    available = yes
    valid users = pi
    read only = no
    browsable = yes
    public = yes
    writable = yes
Lets examine that.
[share]
    valid users = pi
    read only = no
[share]
    read only = no
[share]
    read only = no
    guest ok = yes
I'd be happy to accept a pull request on changes to the docs in this area.
Posted: Fri Mar 15, 2019 3:29 pm
by Thoughtfission
Thanks for your replies, they were very helpful. I am almost there. I have the shares mounted at /media/pi/USBDiskName.
There is one final issue. When I try to connect to the share from my mac (Connect to server then smb://xxx.xxx.xxx.xxx) I can connect with no problem as pi. But when I connect as the user I created (my name) the pi refuses the connection unless I connect to my home account. I can see the shared disks I want to connect o but it won't let me connect.
I assume this is a permission problem of some sort but I can't figure out what the issue is.
Help!
Posted: Fri Mar 15, 2019 4:13 pm
by hortimech
And I would be quite willing to totally rewrite your Samba page, just not on git-hub, we left there and went to git-lab.
Posted: Fri Mar 15, 2019 4:34 pm
by Thoughtfission
Jamesh and Hortimech, I have no idea what you guys are talking about? :?
Posted: Fri Mar 15, 2019 5:47 pm
by hortimech
Hi Thoughtfisssion, I am a member of the Samba team and I have been trying, for some time, to point out to the Rpi team that their Samba page isn't correct and all I get is 'use git-hub'. I will not use git-hub, well not after Microsoft bought it.
If anybody has any problems with Samba, can I suggest that they read the Samba wiki, instead of the Rpi Samba wiki page:
https://wiki.samba.org/index.php/Main_Page
I can and do edit that
Posted: Fri Mar 15, 2019 5:58 pm
by Thoughtfission
Hi Hortimech. Thanks, now I understand.
Did you happen to see my post above? I still can't access the share as anyone other than "pi"
Posted: Sat Mar 16, 2019 8:52 am
by hortimech
OK, lets start by you posting your smb.conf
But before you post it, remove all lines that start with a '#' or ';'
Posted: Sat Mar 16, 2019 9:57 pm
by Thoughtfission
Great, thank you. I've changed the names of the users to Z1 and Z3 and the corresponding share and disk names for privacy.
[global]
encrypt passwords = yes
username map = /etc/samba/user.map
syslog = 0
map to guest = bad user
max log size = 1000
workgroup = WORKGROUP
writeable = yes
usershare allow guests = yes
passwd program = /usr/bin/passwd %u
pam password change = yes
obey pam restrictions = yes
panic action = /usr/share/samba/panic-action %d
dns proxy = no
unix password sync = yes
security = user
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
passdb backend = tdbsam
server role = standalone server
log file = /var/log/samba/log.%m
[homes]
comment = Home Directories
browseable = no
read only = no
read only = yes
create mask = 0755
directory mask = 0755
valid users = %S
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
[public]
comment = public storage
path = /home/shares/public
valid users = @users
force group = users
create mask = 0660
directory mask = 0771
read only = no
[share]
path = /home/pi/Desktop/share
available = yes
valid users = pi
read only = no
browsable = yes
public = yes
[Z1_Share]
path = /media/pi/Z1_Disk
available = yes
valid users = pi, Z1
read only = no
[Z2_Share]
path = /media/pi/Z2_Disk
available = yes
valid users = pi, Z1, Z3
read only = no
[Z3_Share]
path = /media/pi/Z3_Disk
available = yes
read only = no
Posted: Sun Mar 17, 2019 9:32 am
by hortimech
This is the smb.conf with all the default settings removed (note it is interspaced with comments)
[global]
security = user
syslog = 0
max log size = 1000
dns proxy = no
Why have you got a user.map ?
It is only really useful on a domain member.
You should remove the line above, it has been found to alter the umask.
[homes]
browseable = no
read only = no
read only = yes
Why have both of the lines above ?
They are exact opposites and the last one wins. If you want to allow writing to the share, remove the last one, if you don't, remove both.
create mask = 0755
valid users = %S
[printers]
browseable = no
printable = yes
create mask = 0700
[print$]
[public]
force group = users
create mask = 0660
read only = no
Interesting, a share called 'public' that isn't. To connect the user must be authenticated and a member of the 'users' group
[share]
valid users = pi
read only = no
guest ok = yes
The 'guest ok = yes' is superfluous, only the user 'pi' can connect, if you want anybody to connect (authenticated or guest), remove the 'valid users' line, if you really want the user 'pi' to be the only user allowed, remove the 'guest ok' line (note: you had the old synonym 'public')
[Z1_Share]
read only = no
Only the users 'pi' and 'Z1' can connect
[Z2_Share]
read only = no
Only the users 'pi', 'Z1' and 'Z3' can connect
[Z3_Share]
read only = no
I note that you are sharing mounted drives, depending on what filesystem they are formatted as and if the required software is installed will affect the way Samba interacts with the shares.
Posted: Sun Mar 17, 2019 2:54 pm
by Thoughtfission
Hi Hortimech,
Thanks for taking the time to do this.
No idea, I didn’t add this. Will delete.
[share]
valid users = pi
read only = no
guest ok = yes
I think this is a cut and paste error on my part. It doesn’t exist in the file.
The drives mounted are etx4 Do you think this will cause problems?
Unfortunately, after making the changes above as per your instructions, I can't connect with any account.
Posted: Sun Mar 17, 2019 5:03 pm
by Thoughtfission
[global]
writeable = yes
dns proxy = no
syslog = 0
security = user
max log size = 1000
[printers]
browseable = no
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
browseable = yes
read only = yes
guest ok = no
[public]
force group = users
create mask = 0660
read only = no
[share]
available = yes
valid users = pi, Z3, Z1
read only = no
browsable = yes
public = yes
[Z1_Share]
path = /media/pi/Grant_Disk
available = yes
read only = no
[Global_Share]
path = /media/pi/Share_Disk
available = yes
read only = no
[Z3_Share]
path = /media/pi/Mary_Disk
available = yes
read only = no
Posted: Sun Mar 17, 2019 5:05 pm
by Thoughtfission
[homes]
browseable = no
read only = no
Posted: Sun Mar 17, 2019 5:11 pm
by Thoughtfission
create mask = 0755
valid users = %S
Posted: Sun Mar 17, 2019 6:40 pm
by hortimech
What are the permissions on the folders you are sharing ?
what do these commands output:
ls -lad /home/shares/public
ls -lad /home/pi/Desktop/share
ls -lad /media/pi/Z1_Disk
ls -lad /media/pi/Z2_Disk
ls -lad /media/pi/Z3_Disk
Does the user you are trying to connect to the share (which share ?) exist in /etc/passwd ?
and is it also a Samba user ?
Posted: Tue Mar 19, 2019 10:16 am
by Thoughtfission
Sorry for the delay in responding. Yesterday was crazy busy.
Here are the answers to your questions (hopefully):
drwxrwxr-x 2 root users 4096 Mar 11 13:45 /home/shares/public
drwxr-xr-x 2 pi pi 4096 Mar 11 14:06 /home/pi/Desktop/share
drwxrwxrwx 4 root root 4096 Mar 14 09:19 /media/pi/Z1_Disk
drwxr-xr-x 4 root root 4096 Mar 1 14:33 /media/pi/Z2_Disk
drwxrwxrwx 3 root root 4096 Mar 15 14:55 /media/pi/Z3_Disk
/etc/passwd entries for the users in question (Z1 is the priority right now)
Z1:x:1001:0:Z1:/media/pi/Z1_Disk:/bin/sh
Z3:x:1002:100:Z3:/home/Z3:/bin/sh
Z1 is a Samba user. Will add Z3 once Z1 is working properly.
Posted: Tue Mar 19, 2019 2:02 pm
by hortimech
OK, if we examine one of those permission lines we find this:
The first block 'drwxrwxrwx' are the permissions
The third and fourth are the owner & group
The last is the path to the directory
Breaking the permissions down, it becomes this:
d rwx rwx rwx
The first letter tells you that they are from a directory.
The first block of 'rwx's is for the owners permissions, the second is for the groups permissions and the last is for everybody else, referred to as 'others'
The three blocks of 'rwx's can be broken down further:
r w x
'r' is for read
'w' is for write
'x' is for (in this case) enter, but, if it was a file, it would be execute.
An absence of a letter i.e. 'r-x' means that permission isn't given, in this case 'write' isn't allowed.
So from that, you will find:
Z1 has full permissions on: /media/pi/Z1_Disk but only through 'others'
Z1 has full permissions on: /media/pi/Z3_Disk but only through 'others'
Z1 can enter and read: /home/shares/public /home/pi/Desktop/share /media/pi/Z2_Disk
Z1 may be able to write to /home/shares/public, but only if 'Z1' is a member of the 'users' group
Posted: Tue Mar 19, 2019 3:18 pm
by Thoughtfission
Hi Hortimech,
Thanks for your answers. The permission thing, rwx and groups/users, I was ok with. Probably one of the few things I remember from my UNIX days. But what I can't understand is why I get message telling me I don't have access to the server when I try to connect the share, Z1_Disk, to my mac (smb://192.168.xxx.xxx)? If I do it as "pi" I have no issues at all. If I do it as user Z1, it just refuses the connection.
BTW, love your answers. You should consider teaching at university! Very detailed and easy to understand.
Posted: Wed Mar 20, 2019 4:33 pm
by hortimech
Hi Hortimech,
you posted this:
Which shows that the user 'Z1' is known to the OS, has the ID '1001', the users primary group is '0' (root group) , its home directory is /media/pi/Z1_Disk and has the login shell /bin/sh
The permissions on /media/pi/Z1_Disk are 'drwxrwxrwx root root'
So, as I said, Z1 should be able to connect via 'others', it should also be able to connect via 'group', so if it isn't, you need to check various things:
Is the share actually mounted
How is it being mounted ?
Did you make Z1 a Samba user with 'smbpasswd -a Z1' (you would have to run this with root or sudo)
What are the permissions on /media and /media/pi ?
Posted: Thu Mar 21, 2019 10:49 am
by Thoughtfission
Yes.
Was mounted automatically when I plugged into the USB port.
Yes.
drwxr-xr-x 3 root root 4096 Mar 11 11:16 media
drwxr-x---+ 5 root root 4096 Mar 21 10:42 pi
Posted: Thu Mar 21, 2019 11:12 am
by hortimech
Hmm, you have this:
This means that only root can read, write and enter the 'pi' directory, members of the root group can read and enter the 'pi' directory, 'others' are denied any access, but this isn't the full picture. If you examine the permissions, you will notice a '+' sign at the end of the permissions, this means that there are extended ACL's set on the share, they are possibly the same as the Unix permissions, but they could be different. To see these extended, you need to use 'getfacl'
getfacl /media/pi
Posted: Thu Mar 21, 2019 11:57 am
by mikerr
jamesh wrote:I'd be happy to accept a pull request on changes to the docs in this area.
hortimech wrote:And I would be quite willing to totally rewrite your Samba page, just not on git-hub, we left there and went to git-lab.
Opposed to github on principle ?
I just submitted a pull request to the Rpi docs to get it fixed, assuming the share was meant to be fully public (guest ok).
Posted: Thu Mar 21, 2019 3:07 pm
by Thoughtfission
Hmm, you have this:
getfacl /media/pi
Hi. Everything is fine now. I needed to install ACL (sudo apt-get install acl) then use setfacl -Rbn on /media/pi to get rid of the ACL permissions. Everything seems to be working now. I wish I could say how those ACL permissions were set in the first place. I have no idea. Maybe something I did in Webmin? Who knows.
Thank you so much for your patience and guidance. It really is appreciated.
