Zbaker1398 wrote:bgirardot wrote:Should be fine for you RPi. The key bit of info is this:
4 x USB Output: 5V 0.6A ~ 2.1A,
The RPi needs 5V @ 700mA (0.7A) or more. The above line seems to indicate it can power up to a total of 2.1A spread across the 4 usb ports.
The answer to the next question is: Probably somewhere between 12 and 20 hours, you will just have to try it and see :) It looks like a pretty nice device.
Ok So could you 'power' a powered USB hub with this also. I don't understand how to make this work. Like how would you get an AC wall plug to be powered from this?
You do not get AC power from this. It is probably best to just say it will power things that typically get their power from a USB port, your RPi, a cell phone, a tablet, etc.
It essentially is a powered USB hub, it is just powered from its own internal battery instead of by a plugged in wall adapter like a 'real' powered usb hub.
This item appears to be charged via a usb cable so it is not a "true" powered usb hub in the sense it plugs into the wall.
