skcasb
How To Execute a Script at Shutdown/Halt on Raspbian Stretch
Fri Feb 08, 2019 9:21 am
Hi All,
I'm using a Raspberry pi 3B+ within Raspian Strecth 9.6.
I need to execute a script that send a command on serial ttyACM0 to switch-off raspberry power-supply, when the command "sudo poweroff" or "sudo halt" are issued.
The source script is visible below:
[Unit]
Description=Turn power off after shutdown
DefaultDependencies=no
Before=umount.target
[Service]
Type=oneshot
ExecStart=/bin/echo "cmd=switchoff" > /dev/ttyACM0
[Install]
WantedBy=halt.target poweroff.target
I tried to use systemd placing a service script on /lib/systemd/system/mypoweroff.service, enable it using
systemctl enable mypoweroff.service
but it seems doesn't work.
I googled for a solution, but until now I have not found anything working.
Do you have any suggestions for me ?
Thank you.
tpyo kingg
Re: How To Execute a Script at Shutdown/Halt on Raspbian Stretch
Fri Feb 08, 2019 10:01 am
Shouldn't that ExecStart be ExecStop instead?
skcasb
Fri Feb 08, 2019 1:53 pm
I just replaced ExecStart to ExecStop as you suggested but I get the following error when a systemctl status mypoweroff.service issued
mypoweroff.service: Service has no ExecStart= setting, which is only allowed for RemainAfterExit=y
Do I need to change or add something on service script ?
Thank you.
tpyo kingg
Fri Feb 08, 2019 4:53 pm
It would need to have RemainAfterExit also.
[Service]
RemainAfterExit=yes
Type=oneshot
skcasb
Mon Feb 11, 2019 11:05 am
Added also RemainAfterExit=yes but I still have the issue.
I think the problem is how ExecStart is written. Comparing the rpi-display-backlight.service file with mine is enough to change ExecStart as follows to solve the problem:
[Unit]
[Service]
Type=oneshot
ExecStart=/bin/sh -c '/bin/echo "cmd=switchoff" > /dev/ttyACM0'
[Install]
tpyo kingg
Mon Feb 11, 2019 11:15 am
I had an error in the example above. Try the two together:
[Service]
RemainAfterExit=yes
Type=oneshot
ExecStop=/bin/echo "cmd=switchoff" > /dev/ttyACM0
skcasb
Mon Feb 11, 2019 3:44 pm
I'm sorry, but using your code I still have this error:
Service has no ExecStart= setting, which is only allowed for RemainAfterExit=yes services. Refusing.
tpyo kingg
Mon Feb 11, 2019 5:18 pm
Did you reload the systemd services and (re-)start the service once you changed the service file?
skcasb
Thu Feb 14, 2019 10:20 am
Yes, also rebooted the raspberry but I still have the same issue using your code.
If I use on "Service" section this code instead of yours
[Service]
Type=oneshot
The service works fine when I issue a poweroff/halt command.
tpyo kingg
Thu Feb 14, 2019 12:11 pm
There are probably many ways to get more or less the same result. Based on tests I get the impression that systemd sometimes has inconsistent behavior. Many times it even fails to boot until power cycled.
Anyway, the following are two of the ways I've gotten a script to trigger upon shutdown.
$ cat /lib/systemd/system/something.service
[[Unit]
Description=Does something upon power off
[Service]
Type=oneshot
RemainAfterExit=true
ExecStart=/bin/sh -c "/bin/date +'0 %T' >> /home/pi/backlight.txt"
[Install]
WantedBy=reboot.target halt.target poweroff.target
Or
[Unit]
[Service]
Type=oneshot
[Install]
WantedBy=multiuser.target
YMMV
skcasb
Thu Feb 14, 2019 1:26 pm
The first script trigger also on reboot.
I need the service only for halt and shutdown, removing reboot.target from "Wanted by" it works fine.
Thank you.
