Toby Branfoot
Power supplies? USB hubs?
Sun Nov 18, 2012 7:58 pm
Hi
I have my Pi on order, and a second planned as a Xmas present ... hopefully delivered in the next week or so.
Farnell have problems delivering a power supply it seems - delays ...
I have a couple of power supplies from "old" HTC TyTN I/II phones with "micro-USB" plugs that will deliver 5V/650mA ... but they are the "old" "bigger" plugs ... not the more modern slimmer design ... are these useless for the Pi?
If so - will "any" phone charger or other micro-USB rated at 5V/700mA work - and if so, what are you all using?
Reading up more - a Model B has 2 USB's but these are needed for the keyboard and mouse ... no options for a wireless USB, etc ... without a hub. I gather powered ones are what's needed ... are any better/worse than others with the Pi? (I gather not all SD cards are the same!)
Practical experience (good or bad), recommendations (the same) ... most welcome
Cheers
Toby
notarat
Re: Power supplies? USB hubs?
Mon Nov 19, 2012 3:22 pm
The vast majority of users use a power supply rated for 5v 1A. That's not to say a 5v 700ma won't work, but having 1A available is better than having only 700ma
If running from a Powered USB Hub, I recommend using one which has power switches for each individual port. This allows you to power off/on the Pi after a shutdown.
freedomotic
Mon Nov 19, 2012 5:06 pm
I'm using the charger of TomTom navigator (5V 1A) with a cable usb-microusb.
It works very well!!
Regards
Freedomotic Open IoT Framework
http://freedomotic.com
tech-fruits
Mon Nov 19, 2012 10:10 pm
Raspy Juice expansion board allows not only to juice up your RasPi through batteries or solar cells, but also gives you the features of a micro-controller for analog inputs and serial connections.
Read about it here - http://www.tech-fruits.com/archives/4972
www.tech-fruits.com - Spreading Sweet Wisdom
Toby Branfoot
Mon Nov 19, 2012 10:50 pm
5V and 750+mA I understand. Confused over varieties of "mini-/micro-SD" what does the RPi use?
Additional USB - this does need to be powered doesn't it? Recommendations? Or will most/any do? Can the powered USD bank power the RPi too?
Additional though - "the literature" suggests 4GB SD cards ... is this just fine for normal people, or a bare minimum?
Cheers
Toby
MattHawkinsUK
Mon Nov 19, 2012 11:17 pm
The "bigger" plugs are mini-USB rather than micro-USB which the Pi uses. You need to be careful when buying products because some people use the wrong terms.
So your old supplies are mini not micro.
I use 700mA Blackberry supplies and they work OK.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
toxibunny
Tue Nov 20, 2012 5:50 am
The pi uses normal sized SD cards, like from your camera. The micro SD (size of a fingernail) ones will work, if you use an adaptor. Don't bother with mini SD...
note: I may or may not know what I'm talking about...
Return to “Beginners”
