Warnerduh
Contact: ICQ Website AOL Skype
Raspberry Pi and OLPC
Thu Jan 17, 2019 10:38 am
The Raspberry Pi SD card we received with the Raspberry Pi Kit is not preloaded with the project instructions. What do we do now?
<a href="https://www.noriualaus.com/panasonic-10-cup-rice-cooker/">https://www.noriualaus.com/</a>
neilgl
Re: Raspberry Pi and OLPC
Thu Jan 17, 2019 11:48 pm
OK where did you get the SD card from? As @pcmanbob said:
I suggest you start by reading the plentiful help pages on the raspberrypi.org site. might I recommend
https://projects.raspberrypi.org/en/pro ... setting-up
https://projects.raspberrypi.org/en/pro ... y-pi-using
https://www.raspberrypi.org/learning/pa ... /physical/
https://projects.raspberrypi.org/en/pro ... -computing
this will help you get set up and introduce you to the pi gpio and how to connect switches and LED's to it.
PhatFil
Fri Jan 18, 2019 1:25 am
fyi the links are dead
meanwhile the OP can start here https://www.raspberrypi.org/documentation/setup/
OLPC?? one laptop per child? or is this a specific project your pi is intended for?
scruss
Fri Jan 18, 2019 1:33 am
I'm not sure those …ified links do what you expect them to do.
Anyway, OLPC as in One Laptop per Child? If you want to run something like it, looks like you have to install Raspbian and then run the Internet-in-a-Box (IIAB) script.
Pronouns: he/him
