IRLionel
Official repository - hostapd not found
Sun Jan 06, 2019 10:00 pm
Hi all,
I've just installed the latest Stretch ( Version 4.14 - Just Desktop i.e without the recommended software ) and I'm trying to create a hotspot.
Done the updates and upgrades.
I was able to install dnsmasq without any issues, but when I try hostapd I get "Unable to locate package hostapd"
Please could I ask someone to verify that its not currently there ?
I am using the standard pre configured sources list:
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Thanks,
Andyroo
Re: Official repository - hostapd not found
Mon Jan 07, 2019 1:37 am
Have you seen this post viewtopic.php?p=1297609
IRLionel
Mon Jan 07, 2019 6:29 am
Hi
Thanks for the reply
I had seen it and tried all the suggestions.
My output of the policy is this:
I dont know enough to know if thats good or bad ?
[email protected]:~ $ sudo apt-cache policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=ui,b=armhf
origin archive.raspberrypi.org
500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=main,b=armhf
500 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages
release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=rpi,b=armhf
origin raspbian.raspberrypi.org
500 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=non-free,b=armhf
500 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=contrib,b=armhf
500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=main,b=armhf
Pinned packages:
Mon Jan 07, 2019 6:51 am
Your output from policy looks the same as mne, but hostapd seems to be available in mine
[email protected]:~ $ apt-cache policy hostapd
hostapd:
  Installed: 2:2.4-1+deb9u2
  Candidate: 2:2.4-1+deb9u2
  Version table:
 *** 2:2.4-1+deb9u2 500
(You don't need sudo to run apt-cache commands as they are purely informational).
IRLionel
Mon Jan 07, 2019 8:47 am
Thanks for checking
There are a surprising number of posts on various sites regarding this same problem and it always seems to mysteriously fix itself.
The fact that I was able to install dnsmasq without any issues, leads me to believe that my settings are all correct.
Ive been trying for a couple of days but will keep at it.
Any suggestions would be appreciated
IRLionel
Tue Jan 08, 2019 3:56 pm
This is definitely going to come up again so here is a brief description on what I did to fix it.
I checked one of my other Pi's and that one loaded the hostapd file no problem. I checked its sources file and it was different to mine ( Which was as I downloaded it )
So to edit the file its: sudo nano /etc/apt/sources.list
Comment out the standard line like this:
#deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Add this line:
deb http://mirrordirector.raspbian.org/raspbian/ stretch main conttrib non-free rpi
Then do:
sudo apt upgrade
and
sudo apt update
After this I was able to load hostapd
pws
Tue Jan 08, 2019 4:02 pm
sudo apt update is FIRST
Then do:
sudo apt upgrade
and
sudo apt update
IRLionel
Tue Jan 08, 2019 7:00 pm
Quite right
Thanks ;)
