james15315
Motor control
Thu Jan 03, 2019 9:36 pm
Hi everyone. Not really sure how this whole forum thing works but I have a motor shield made by sb components for my raspberry pi. I am a novice programmer and have been searching the web to try and find help with making a simple code for my raspberry pi to be able to control a motor. Could anyone help me?
drgeoff
Re: Motor control
Thu Jan 03, 2019 10:58 pm
Did you try putting "sb components motor shield" into a search engine? I did that and clicked on https://sb-components.co.uk/motor-shield.html. Then looked at that page. Guess what is at the bottom.
joep6120
Re: Motor control
Sun Sep 01, 2019 10:55 pm
i have this motor control hat as well and have downloaded the sample codes from github but for some reason the stepper motor code won't work
this is the code:
import PiMotor
import time
import RPi.GPIO as GPIO
m1 = PiMotor.Stepper("STEPPER1")
# Rotate Stepper 1 Contiously in forward/backward direction
while True:
m1.forward(0.1,10) # Delay and rotations
time.sleep(2)
m1.backward(0.1,10)
time.sleep(2)
except KeyboardInterrupt:
GPIO.cleanup()
this is the error i get:%Run Stepper_Test.py
File "/home/pi/Downloads/MotorShield-master/Stepper_Test.py", line 14
SyntaxError: invalid syntax
can someone tell my whats wrong as i am new to this programming stuff :?
markkuk
Re: Motor control
Mon Sep 02, 2019 5:41 am
You don't have a "try" keyword before "except". See the Python tutorial on exception handling: https://docs.python.org/3.7/tutorial/er ... exceptions
The code should look like this:
try:
  while True:
    time.sleep(2)
    m1.backward(0.1,10)
    time.sleep(2)
  GPIO.cleanup()
