tony1812
Show ip at boot
Thu Dec 20, 2018 10:27 pm
Hello, I have a script like this:
import socket
import fcntl
import struct
def get_ip_address(ifname):
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    return socket.inet_ntoa(fcntl.ioctl(
        s.fileno(),
        0x8915,  # SIOCGIFADDR
        struct.pack('256s', ifname[:15])
    )[20:24])
print get_ip_address('lo')
print get_ip_address('wlan0')
I run it in the terminal, all is fine.
Now I want to make it so that it shows the ip of the pi, so in ~/.config/lxsession/LXDE-pi/autostart
I added these lines
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@[email protected] s noblank
@xset s off
@xset -dpms
@sudo python /home/pi/Desktop/my_ip.py
when I reboot, it doesn't show anything, what gives?
Re: Show ip at boot
Thu Dec 20, 2018 10:32 pm
Try this program which gets both your LAN and public IPv4 addresses.
#!/usr/bin/python3
from urllib.request import urlopen
import json
import socket
from tkinter import *
rootWindow = Tk()
rootWindow.title('IP Addresses')
localIP = Label(rootWindow, font = ('fixed', 20),)
localIP.grid(sticky = N, row = 2, column = 1, padx = 5, pady = (20,20))
publicIP = Label(rootWindow, font = ('fixed', 20),)
publicIP.grid(sticky = N, row = 3, column = 1, padx = 5, pady = (20,20))
hostName = Label(rootWindow, font = ('fixed', 20),)
hostName.grid(sticky = N, row = 1, column = 1, padx = 5, pady = (20,20))
ip = urlopen('http://httpbin.org/ip').read()
ip = ip.decode('utf-8')
ip = json.loads(ip)
testIP = "8.8.8.8"
s.connect((testIP, 0))
ipaddr = s.getsockname()[0]
host = socket.gethostname()
localIP.config(text=ipaddr)
publicIP.config(text=ip['origin'])
hostName.config(text=host)
print(ip['origin'], "IP:", ipaddr, " Host:", host)
rootWindow.mainloop()
This is a doctor free zone.
klricks
Re: Show ip at boot
Thu Dec 20, 2018 10:43 pm
Try this:
@lxterminal -e python /home/pi/Desktop/my_ip.py
Note: If your program exits to the command line for any reason then the terminal will immediately close and you won't see anything.
tony1812
Re: Show ip at boot
Fri Dec 21, 2018 9:45 pm
Thank everyone.
I like DougieLawson's solution. It shows up in a nice window. Except for the damn SSH warning blocks it :(
Re: Show ip at boot
Sat Dec 22, 2018 11:39 am
Change the password for the pi userid to any string other than "raspberry" and that nagware pop-up will go silently into hibernation (it'll pop-up again if you change the password back to "raspberry").
