simoselva
Audio with Pi zero
Fri Dec 07, 2018 1:27 pm
Hello everyone,
I'd like to know if a very small speaker, connected to the Pi zero (through pins), always needs an amplifier.
I want to build a small paint that reproduce a voice speech over the press of a button, but I want to keep price as low as possible.
Since I don't need an high volume, do you think that I can avoid the usage of the amplifier?
Regards,
Simone
Re: Audio with Pi zero
Fri Dec 07, 2018 3:14 pm
Hello everyone,
Regards,
Simone
https://learn.adafruit.com/introducing- ... io-outputs#
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
simoselva
Fri Dec 07, 2018 4:02 pm
Thanks, but I already found that guide.
I'll try to clarify, my question is: can I use the Pi zero for audio WITHOUT AN AMPLIFIER? I need a low volume, hearable from a distance of about 1 or 2 meters
drgeoff
Fri Dec 07, 2018 4:10 pm
Hearable if you you use a high sensitivity loudspeaker in a quiet environment. The only way to know if it will meet your requirement is to try it yourself.
echmain
Fri Dec 07, 2018 5:06 pm
Maybe give this little thing a try:
https://shop.pimoroni.com/products/speaker-phat
ait
Fri Dec 07, 2018 5:24 pm
No
https://www.ebay.de/itm/Arduino-PAM8302 ... rk:14:pf:0
simoselva
Fri Dec 07, 2018 5:39 pm
No
Oh, wonderful, manu thanks
Brandon92
Fri Dec 07, 2018 6:07 pm
A other idea would be to use something like this.
Burngate
Fri Dec 07, 2018 6:43 pm
The Pi's GPIOs can each supply about 16mA, and 0v-3v3
So to keep things safe the load on the GPIO would have to be 220Ω or greater (3.3 / 0.016)
And the power output would be about 50mW (3.3 * 0.016)
If your speaker is 220Ω or greater, and 50mW is sufficient, then yes, you don't need an amplifier. Otherwise no.
