pertm84
Crontab Issue - AKA not working?
Sat Nov 24, 2018 3:24 pm
Hi
So I am new to this world of working with cmdline interfaces, and I do not understand it well enough to know what to do (improvise), but I am good at googling the subject and copy/paste the code where it should be.
However, I seem to have confused myself with the crontab usage. I am running Raspbian Stretch on a Rpi2.
I have made two scripts which I want to run every 25 and 15 minutes.
First script
sudo nano motionrestart.sh
containing:
#!/bin/bash
sudo service motion restart
then I made it runnable:
sudo chmod +x motionrestart.sh
I tested it with
./motionrestart.sh
Then I made a python script to run the bash.script with python:
sudo nano motionrestart.py
containing:
#!/usr/bin/env python
import shutil
import os
os.system("bash -c /home/pi/bin/motionrestart.sh")
2nd script:
#!/bin/bash
filename= ^`^|/tmp/image.jpg ^`^|
hostname="webcam.wunderground.com"
username="xxx"
password="xxx"
lftp ftp://$username:[email protected]$hostname -e "put /tmp/image.jpg ; quit"
made it runnable and tested it, then I made the python script:
import shutil
import os
os.system("bash -c /home/pi/bin/wunderftp.sh")
So this is where the confusion starts, I added this to root user crontab -e:
*/15 * * * * /home/pi/bin/wunderftp.py
*/25 * * * * /home/pi/bin/motionrestart.py
Because I didn't remember I added it to root, I added the cronjob to the user pi as well.
Will this cause confusion? Shall it only be root? I am accessing the system through SSH, and I have disabled root access through ssh.
What if I remove the crontab from root, and only manage cronjobs through the user pi?
PhatFil
Re: Crontab Issue - AKA not working?
Sat Nov 24, 2018 5:20 pm
try prefixing your path/script.py with "python " in your crontab entry
*/15 * * * * python /home/pi/bin/wunderftp.py
*/25 * * * * python /home/pi/bin/motionrestart.py
or python3 if using Python3...
https://www.dexterindustries.com/howto/ ... pberry-pi/
pertm84
Sun Nov 25, 2018 10:50 am
Added python as you suggested, and thank you, that seemed to do the trick! :)
mfa298
Sun Nov 25, 2018 11:53 am
Hi
First script
containing:
#!/bin/bash
Three of your four scripts seem to be adding complexity for no real gain.
You could replace the first two scripts (the bash and python) with a single root cron entry
*/25 * * * *  service motion restart
I would put that one in the root crontab as it needs to run with root perms, you could put it in the pi crontab if you added sudo to the command. Ideally you should probably use systemctl rather than service but that's a seperate thing.
Your 2nd part I'd run from the pi crontab (as it looks like it should run as the pi user), the python script also seems a bit redundant, you could run the bash script direct from cron.
*/15 * * * * /home/pi/bin/wunderftp.sh
Return to “Beginners”
