Hi, I've possibly got a chicken and egg situation/question:
First just to make sure I'm not making any idiot mistakes/assumptions. My raspberry pi 3 (RP3) has 1 SD card slot and 4 USB (standard), and one micro USB port (power), and an HDMI port. There is also what appears to be a legacy display port intended for simple display that I have no interest in at this time.
Now my situation is that I would like to use a 128GB SDXC card to run the RP3 from (I'm a firm believer in the old adage that you can never have enough storage or speed). My RP3 currently is running from a 32GB SD card. The SDXC card is formatted as exfat. I have mounted it on my main machine running SUSE 42.1. My understanding is that the standard Raspberry Pi OS, Raspian, is not built with exfat capability. But that it can be added to a running system. But if I want to install Raspian to the SDXC card
1. can it boot if the card is exfat? What formats are acceptable to
2. what are other alternatives for using the 128GB card?
a. reformat it to ext/3/4 ?
b. use a different linux OS distribution? which one?
Think that's it for the moment. No, I have no idea why I would need 128GB. But like I said above I believe you can never have enough storage.
best regards
jjefferies
