atulkatti
Booting Raspberry pi from your laptop
Fri Oct 26, 2018 11:36 am
I was able to setup PI by connecting it to display and then connecting it to wifi. Now i need to take my pi to another site and connect to wifi there. I may not be able to find a display to connect to over there. How can i boot it through my laptop so that i can then add wifi details in Pi.
Re: Booting Raspberry pi from your laptop
Fri Oct 26, 2018 11:49 am
https://www.raspberrypi.org/documentati ... ess-cli.md
RPi 4B 4GB (SSD Boot)..
atulkatti
Fri Oct 26, 2018 3:24 pm
But isnt this useful only when your laptop and pi are connected to same wifi, but then you want to connect to another network. In my case i wont know before hand what the ssid and pwd for new network is. When i go to this new place i will not have my old wifi network
Fri Oct 26, 2018 3:35 pm
Well you quoted "Booting Raspberry pi from your laptop" which is only feasible if you are running your Laptop as a Server and the RPi is a Client.
So I wrongly assumed you would be using your Laptop between the RPi and whatever Wireless Device.
atulkatti
Fri Oct 26, 2018 4:17 pm
ok what if i connect my laptop to wifi, then how can i connect the Pi to wifi ?
Pedro_Lopes
Fri Oct 26, 2018 4:31 pm
https://www.hackster.io/pedromflopes
HawaiianPi
Sun Oct 28, 2018 1:26 am
If you know the WiFi credentials you can create a file called wpa_supplicant.conf on the small FAT32 "boot" partition of a Raspbian imaged SD card, and that will be moved to its correct location and used to connect to the network when the Pi starts up.
My wpa_supplicant.conf file looks like this.
update_config=1
country=GB
network={
	ssid="Your network SSID"
	psk="Your WPA/WPA2 security key"
	key_mgmt=WPA-PSK
Edit country=, ssid= and psk= with your information (use a pure text editor, not a word processor).
If you haven't already done so, you can enable SSH at boot time by adding an empty file named ssh (or ssh.txt) to that same "boot" partition.
There is also something called a serial console cable that will let you log into your Pi without a network connection. I use cheap CP2102 USB-TTL (3V3) adapters I get from ebay for less than 2 bucks.
There may be other options as well, depending on what model Raspberry Pi you have (if it's a Pi Zero, you also have USB Gadget mode, which will let you SSH in over USB).
jbudd
Sun Oct 28, 2018 10:30 am
Use the mobile hotspot feature of your smartphone.
/etc/wpa_supplicant/wpa_supplicant.conf can have the login details for more than one wifi network:
update_config=1
country=GB
network={
        ssid="MyPhone"
        psk="Aardvark"
network={
        ssid="MyHomeWifi"
        psk="Pangolin"
network={
        ssid="ThePub"
        psk="Echidna"
With both the laptop and Pi connected to your phone you can login by ssh and add a stanza for the new network to wpa_supplicant.conf.
