sshivasagaran
Unable to establish communication Temperature meter to my Rasbperry pi
Fri Oct 19, 2018 9:01 am
this the code i am using
import pymodbus
import serial
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(15, GPIO.OUT)
from pymodbus.client.sync import ModbusSerialClient as ModbusClient
client = ModbusClient(method='rtu', port='/dev/ttyAMA0', timeout=1, stopbits = 1, bytesize = 8,
parity='N', baudrate= 38400)
client.connect()
while True:
temp = client.read_holding_registers(address=1, count=1, unit=1);
print temp.registers[0] / 100;
Which gives this error Error No 25 Inappropriate ioctl for device.
Andyroo
Re: Unable to establish communication Temperature meter to my Rasbperry pi
Fri Oct 19, 2018 12:56 pm
What type of temperature meter are you using?
How is it connected to the Pi? (I.e. what interface card for MODBUS to Pi is being used).
Need Pi spray - these things are breeding in my house...
boyoh
Fri Oct 19, 2018 7:08 pm
Be more explicit, is it a temperature sensor ,if so give type and make
Or more details on meter you are using
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
Return to “Beginners”
