installing Mu
Posted: Mon Oct 15, 2018 4:14 pm
by 210338jim
Trying to install Mu on rpi - advised to go to Preferences then Recommended Software but there is no Recommended Software under Preferences
Re: installing Mu
Posted: Mon Oct 15, 2018 4:17 pm
by B.Goode
What Operating System is running on your RPi?
If it is the Raspberry Pi Foundation recommended and supported Raspbian Operating System, what named or dated version?
Re: installing Mu
Posted: Mon Oct 15, 2018 6:57 pm
by gkaiseril
See Pi blog MU, A NEW PYTHON IDE FOR BEGINNERS for the announcement and the link to the guide Getting started with Mu. It looks like you only need to apply the current dist-update to Raspian. Then it will be listed in the Recommended Software menu item.
Re: installing Mu
Posted: Mon Oct 15, 2018 7:33 pm
by DirkS
Both 'recommended software' and 'mu' are only available for Raspbian Stretch.
It needs more than just an update if you're running Jessie (or older)
Re: installing Mu
Posted: Mon Oct 15, 2018 7:52 pm
by fbe
... and if you installed Raspbian Stretch from an image before 2018-06-27, you may need to install the rp-prefapps package to get the Recommended Software menu item under Preferences.
Re: installing Mu
Posted: Mon Oct 15, 2018 8:21 pm
by gkaiseril
Installing Mu on Linux for the command line. To add it to the menu, you can use the menu editor.
Re: installing Mu
Posted: Mon Oct 29, 2018 4:23 am
by mxwll1011
I did not get the "recommended software" drop-down menu after update/upgrade...
sudo apt-get update
sudo apt-get dist-upgrade
SO, I tried to install mu editor via the command line terminal...
pip3 install mu_editor
THIS is the result...
Downloading/unpacking mu-editor
Downloading mu_editor-1.0.1-py3-none-any.whl (1.9MB): 1.9MB downloaded
Downloading/unpacking pyserial==3.4 (from mu-editor)
Downloading pyserial-3.4-py2.py3-none-any.whl (193kB): 193kB downloaded
Downloading/unpacking qscintilla==2.10.7 (from mu-editor)
Could not find any downloads that satisfy the requirement qscintilla==2.10.7 (from mu-editor)
Cleaning up...
No distributions at all found for qscintilla==2.10.7 (from mu-editor)
Storing debug log for failure in /home/pi/.pip/pip.log
SO, the step-by-step instructions at https://codewith.mu/en/howto/install_raspberry_pi ... didn't work. Any thoughts?
Re: installing Mu
Posted: Wed Oct 31, 2018 5:02 pm
by hippy
That guide says -
You can also install Mu from the command line using the command:
sudo apt-get install mu-editor
You didn't do that. You used pip3.
Re: installing Mu
Posted: Thu Nov 01, 2018 2:48 am
by mxwll1011
"E: Unable to locate package mu-editor"
Re: installing Mu
Posted: Thu Nov 01, 2018 8:46 am
by DirkS
You're very conservative with giving information.
You should tell us the exact command you used and the full error msg.
And I don't think you have told us which OS + version you're using...
Important to know in this case.
Re: installing Mu
Posted: Sat Jun 20, 2020 6:12 pm
by pluckerpete
I also previously tried all advice on forums about getting recommended software menu item working but this proved beyond me so I went for cmd installtion option.
I have the same error message after following all the previous steps on this thread.
I had typed in sudo apt-get install mu-editor
The error is unable to locate package mu-editor.
My Pi has just been updated and its details are:
a01041 2B 1.1 1GB Sony UK
Thanks.
Re: installing Mu
Posted: Sun Jun 28, 2020 8:52 am
by hippy
Works for me, Pi 3B (non-plus), Raspberry Pi OS Desktop ...
pi@Pi3B:~ $ sudo apt-get install mu-editor
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  firmware-microbit-micropython fonts-inconsolata fonts-lyx libjs-jquery-ui
  ... snip ...
  python3-zmq
Suggested packages:
  firmware-microbit-micropython-doc libjs-jquery-ui-docs libqscintilla2-doc
  ... snip ...
  python3-twisted firmware-microbit-micropython-dl python3-uflash-doc
  ... snip ...
  python3-zmq
0 upgraded, 50 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.8 MB/19.7 MB of archives.
After this operation, 71.5 MB of additional disk space will be used.
Do you want to continue? [Y/n]
pi@Pi3B:~ $ apt search mu-editor
Sorting... Done
Full Text Search... Done
mu-editor/stable 1.0.2+dfsg-3 all
  simple editor for beginner Python programmers
mu-editor-doc/stable 1.0.2+dfsg-3 all
  simple editor for beginner Python programmers (documentation)
Re: installing Mu
Posted: Sun Jun 28, 2020 8:58 am
by B.Goode
Thanks.
What Operating System are you running on your RPi2B board? Because the mu editor is pre-installed by default with the Full variant of the current RasPiOS Buster Operating System.
Edit: interesting to note that the same request for information about the Operating System was the first reply offered when the topic was first posted nearly 2 years ago...
