Add/Remove Software
Posted: Mon Oct 15, 2018 10:57 am
by ItZskyler
I got my pi for a few days now but i installed Code::Blocks and i want to uninstall it but i don't know how :|
Re: Add/Remove Software
Posted: Mon Oct 15, 2018 11:54 am
by DirkS
How did you install it? Did you follow any instructions?
Posted: Mon Oct 15, 2018 1:34 pm
by ItZskyler
it said i needed to fill in my pass and i did then it was installed, and i used the thing in the prefrences tab
Posted: Mon Oct 15, 2018 1:39 pm
by DirkS
Ok..... but can you be a bit more specific...
What said you needed to fill in your 'pass'.
And what 'thing' did you use in which preferences tab?
Can you provide a link if you followed instructions found on the web?
Posted: Mon Oct 15, 2018 1:44 pm
by ItZskyler
i did not follow instructions and the thing i mean is in the tab Preferences > Add / Remove Software and pass = password
Posted: Mon Oct 15, 2018 1:57 pm
by DirkS
Ok, at least now it's clear how it was installed.
Several ways of removing it.
1. Go to 'add / remove software' again and find codeblocks (e.g. by typing it in the search box at the top left and then pressing <enter>).
Remove the tick in front of it and then click Apply or OK and follow the instructions.
2.. Open a terminal window (Menu / Accessories / Terminal) and enter these commands
sudo apt purge codeblocks
sudo apt autoremove
Posted: Mon Oct 15, 2018 3:05 pm
by ItZskyler
Thx, btw how do i install sublime text 3 on there?
Posted: Mon Oct 15, 2018 3:20 pm
by scruss
Sublime Text doesn't run on ARM.
Posted: Mon Oct 15, 2018 3:24 pm
by gkaiseril
Sublime Text is not part of the Raspberry Pi Package Repository.
Have you looked at the Sublime Text site's download page?
Rasbian is a Linux/Unix 32 bit distro of debian on an ARM processor.
For instructions use the appropriate instructions at https://www.sublimetext.com/docs/3/linu ... ories.html
You might want to check Sublime's support forum.
Sublime Text for Raspberry Pi 3 with Rasbian OS this supports the above reply.
Posted: Mon Oct 15, 2018 3:27 pm
by DirkS
AFAIK there is no Arm / Pi version of sublime-text.
Posted: Mon Oct 15, 2018 3:39 pm
by ItZskyler
Wich ide do you guys recomend(with autocomplete ;) )
Posted: Mon Oct 15, 2018 4:02 pm
by DirkS
I actually quite like vscode. Several languages supported out of the box and there are more available through plugins.
Arm / pi versions are built by 'headmelted'.
Installation instructions are available at https://code.headmelted.com/ (section Linux / APT instructions)
Posted: Mon Oct 15, 2018 4:13 pm
by ItZskyler
how do i install it?
Posted: Mon Oct 15, 2018 4:23 pm
by DirkS
This should do it (easiest to use copy & paste to enter the commands especially the second line)
sudo -s
. <( wget -O - https://code.headmelted.com/installers/apt.sh )
sudo apt update
sudo apt install code-oss
After intallation you should have an entry 'Code - OSS' in the Programming menu
If you decide to uninstall it again you can just run
sudo apt purge code-oss
Posted: Mon Oct 15, 2018 4:29 pm
by ItZskyler
E: Unable to locate package code-oss
Visual Studio Code Install failed.
Posted: Mon Oct 15, 2018 5:21 pm
by DirkS
Is that the output of the install procedure or did you add the second line manually?
Can you post the output of
apt policy
Posted: Mon Oct 15, 2018 5:26 pm
by ItZskyler
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=ui,b=armhf
     origin archive.raspberrypi.org
 500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=main,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/rpi armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=rpi,b=armhf
     origin mirrordirector.raspbian.org
 500 http://mirrordirector.raspbian.org/raspbian stretch/non-free armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=non-free,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/contrib armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=contrib,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=main,b=armhf
Pinned packages:
Posted: Mon Oct 15, 2018 5:54 pm
by DirkS
Ah... it seems there's a problem with the installation procedure at the moment.
https://github.com/headmelted/codebuild ... -428256136
Posted: Mon Oct 15, 2018 6:03 pm
by ItZskyler
what do i need to do now?
Posted: Mon Oct 15, 2018 6:45 pm
by gkaiseril
Wait for the developer to resolve the problem.
Posted: Mon Oct 15, 2018 6:54 pm
by ItZskyler
Is he done?
Posted: Mon Oct 15, 2018 7:21 pm
by DirkS
Is he done?
Well, if you follow the link it should be clear that the dev has not said it should be fixed now.
So that's a no.
Posted: Tue Oct 16, 2018 6:04 am
by ItZskyler
Posted: Sat Oct 20, 2018 6:12 pm
by ItZskyler
WARNING: The following packages cannot be authenticated!
  code-oss
Install these packages without verification? [y/N]
