fabolandry
Amazon Kinesis Video stream
Sun Oct 14, 2018 6:21 pm
I was trying to follow the step in the tutorial below :
https://docs.aws.amazon.com/kinesisvide ... p-rpi.html
I am stuck at step 5 of "Install Software Prerequisites":
Basically, I am supposed to copy a certain file to "/etc/ssl/cert.pem: "
That directory doesn't even exist. I don't get it. As anyone tried this tutorial before? Are we suppose to create a new directory?
Can someone please elaborate for me?
topguy
Re: Amazon Kinesis Video stream
Mon Oct 15, 2018 11:04 am
Just create "/etc/ssl" its where you install server certificates etc.
You might do an "sudo apt install ca-certificates" to see if that creates the directory, but probably not required.
fabolandry
Sat Oct 20, 2018 7:40 pm
What I did I went into /etc/ssl/ by doing
< $ cd /etc/ssl>
then I did
<$ nano cert.pem>.
Then I pasted the content of the file provided in the link. When I try to save I have the error message
[Error writing cert.pem: Permission denied].
Please help
topguy
Sat Oct 20, 2018 8:39 pm
/etc is system files.. use "sudo nano cert.pem"
fabolandry
Sat Oct 20, 2018 11:31 pm
Thanks a lot. I tried that and it worked. Is it a good practice to create pem file using nano?
topguy
Sun Oct 21, 2018 2:43 am
Doesnt really matter how you create it.. best (easiest) way is to just copy the file from somewhere.
Return to “Beginners”
