'Build a Python Web server with flask' - BLOCKER. Cant get flask.
Posted: Sat Oct 13, 2018 9:40 pm
by itsnej
Hey guys,
Finally decided to start using my pi for something and worked through a few physical computing tutorials, now moved on to the 'Build a Python Web server with flask' project, but have encountered a problem. Project link https://projects.raspberrypi.org/en/pro ... th-flask/3'
When I go to
sudo apt-get install python3-flask
, I get the below output, which says it canT find flask.
I've spent a few hours today and yesterday looking for solutions, and have done sudo update, upgrade and reboots a few times. I edited my sources.list and uncommented the 3rd line and at least made some progress when i do a sudo apt-get source flask, when im told its:
Skipping already downloaded files 'flask_0.8-1.dsc', flask_0.8.orig.tar.gz, and flask_0.8-1.debian.tar.gz, but I don't know what to do from there:
Is there any way somebody could help me get flask imported and installed, or explain what I need to do please? Real head scratcher for me and I'm a little bit surprised and disappointed to have been stumped so easily.
Cheers!
Re: 'Build a Python Web server with flask' - BLOCKER. Cant get flask.
Posted: Sun Oct 14, 2018 12:38 am
by topguy
Which version of Raspbian are you running ?
The name of the package should (afaik) be "python-flask" or "python3-flask" in Raspbian Stretch.
You can probably check with the command "apt-cache search flask"
Of course since this is Python I guess "pip install flask" or "pip3 install flask" also could be an option.
Posted: Sun Oct 14, 2018 6:40 pm
by itsnej
Looks like I'm using Wheezy version 7, and some quick googling seems to tell me I should be using Jessie. I thought doing the sudo-apt updates and installs would have put me on the best possible footing with regards to OS tbh.
Will try Jessie out and report back if it works.
Posted: Sun Oct 14, 2018 6:59 pm
by DirkS
Actually, you should be using Stretch.
Posted: Mon Oct 15, 2018 8:36 am
by mfa298
Apt will normally only update within a version, so you'll stay on wheezy. There are ways to upgrade from Wheezy -> Jessie > Stretch with apt (and editing some files) but it's generally easier and quicker to get the latest image and use that.
Posted: Mon Oct 15, 2018 7:42 pm
by itsnej
Cool, so I updated to Jessie and seem to have got it working, thanks a lot for that.
I'll look at moving to Stretch soon, but for now Jessie is working great.
Cheers!
