is there a way to change the resolution on the pi? I have this hooked to a 32 inch flat screen, I changed the overscan to let u know first. But my web pages and all are blown out of proportion. I need to make them smaller inside the block. any suggestions?
tks
rinky
- Contact: Website Yahoo Messenger
- mahjongg
- Forum Moderator
Re: resolution question
choose a different resolution using the same raspi-config utility you used to change the overscan.
ok thank you. i will have to look back for the command. I believe it was /boot/config but i will get to that later for i have a online course here in a hour. I'll let you know how it goes.
tks again for the help
rinky
rinky
sudo nano /boot/config.txt that did the trick. I was afraid to change that before but not now. tks again#
rinky
rinky
