fjr
use rp 0 to flash a teensy 2.0?
Mon Oct 08, 2018 7:51 pm
rp 0
raspbian
https://github.com/CRImier/EEEoma/blob/ ... /README.md
Can I use the rp 0 to flash a teensy 2.0? Can the teensy loader cli be compiled on the rp 0?
Is there other software I can use to flash the teensy 2.0? Thanks.
Tylersuard
Re: use rp 0 to flash a teensy 2.0?
Tue Oct 09, 2018 1:51 am
Hi! I think you would need to download and install the Arduino IDE on your Rpi: https://www.arduino.cc/en/Guide/Linux
Then use it like you would on a normal computer: compile, flash, etc.
scotty101
Tue Oct 09, 2018 8:31 am
Probably.
Why don't you download the teensy_loader_cli source files, open a terminal window, navigate to the folder with the source code and type 'make'.
Only dependency seems to be libusb.
