fjr
[solved] rp zero powered from 5v 4a power supply?
Sun Oct 07, 2018 4:42 pm
Power a rp 0 from a 5v 4a power supply?
Thanks.
Brandon92
Re: rp zero powered from 5v 4a power supply?
Sun Oct 07, 2018 4:49 pm
Yes. That is possible.
B.Goode
Sun Oct 07, 2018 4:52 pm
Thanks.
Raspberry Pi Foundation documentation on this topic is here:
https://www.raspberrypi.org/documentati ... /#pi-power
HawaiianPi
Sun Oct 07, 2018 6:37 pm
Can you do it?
Yes, provided the power supply has good voltage regulation and will not go above 5.25V at the low load levels the Pi Zero will use.
When a power supply is rated for 5V and 4A it means it can output 5V at up to 4A. It won't always output 4A, regardless. It will only output what the device needs, and in the case of the Pi Zero that will usually be well under 1A (so there is no advantage in using a 4A PSU on a Pi0).
fjr
Mon Oct 08, 2018 7:43 pm
Thank you.
