erondem
How to shut down a program ?
Mon Oct 01, 2018 11:13 am
In my raspberry, there is a program running at startup and when I try to kill with command
sudo kill -9 PIDNUMBER
the program just restarts itself again. Program has written before but not by me.
I looked for methods to start a program at boot and check them but none of them helped me. (https://www.dexterindustries.com/howto/ ... t-startup/)
So it is a reverse engineering question. If a C program restarts itself after sudo kill command where should I look to disable it?
RaTTuS
Contact: Twitter YouTube
Re: How to shut down a program ?
Mon Oct 01, 2018 11:18 am
depends on the program ,
but if this is started via systemd look at the service file as it may have options set for restart
what is this program ,
where has it come from
why do you want to stop it
Covfefe
topguy
Mon Oct 01, 2018 11:24 am
Could have been helpful to know the name of the program.
If the program is installed as a "service" then the "systemd" is responsible of restarting the service if it stops for any reason.
To list all the services registered use the command "systemctl".
To correctly stop a service use "systemctl stop name".
To disable it completely use "systemctl disable name".
erondem
Mon Oct 01, 2018 11:28 am
It is a C program which sends sensor data to a server. I made some changes, since I couldnt shut the first version I can not test properly.
It is under /usr/ folder.
What should I search in the systemd folder?
Edit:
Thanks for helpful comment. I couldn't find the name of my program in the list when I enter systemctl
topguy
Mon Oct 01, 2018 11:37 am
rgrep "name" /etc/systemd
This would be a quick way to see if there are any installed services for the program.
erondem
Mon Oct 01, 2018 11:46 am
Can this somehow be related with "avahi"? When I entered ps -eaf I see there :
avahi-daemon: running [NAMEOFMYPROGRAM.local]
DirkS
Mon Oct 01, 2018 12:01 pm
Don't think so. That's most likely
avahi-daemon: running [NAMEOFYOURASPBERRYPI.local]
DirkS
Mon Oct 01, 2018 12:06 pm
You would also have to check /lib/systemd
And you can also use <TAB> completion; it works with all the systemctl commands.
'systemctl status ' + <TAB> will show all 350+ or so services.
