ascotguy
Mounting USB Drive
Wed Nov 07, 2012 8:36 pm
I have a 16gb HP USB drive I am trying to mount automatically.
I have been following this thread - http://www.raspberrypi.org/phpBB3/viewt ... 8&p=206459
I have the following line in /etc/fstab
/dev/sda1 /mnt/usbhd ext4 auto,user,rw,exe 0 3
But when I use "mount -a". I get;
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Can anyone help with the next step? Many thanks
broo0ose
Re: Mounting USB Drive
Wed Nov 07, 2012 9:38 pm
is it an ext4 filesystem? That's the linux default.
If the drive was formatted for Windows then it is probably NTFS, so the fstype should be ntfs.
ascotguy
Thu Nov 08, 2012 8:42 am
Thanks, I will try NTFS.
The only machine I have plugged the USB drive into is my PI but it may have been preformatted.
Is there any way to check the forward and if need be, any way to reformat to a different fs type?
Thanks,
tedhale
Thu Nov 08, 2012 1:59 pm
If it came pre-formatted, then it is probably FAT32 file system.
Windows could create an NTFS system, but I think it defaults to FAT32 for removable media to improve compatibility.
Try vfat as the file system type.
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
flyinghappy
Thu Nov 08, 2012 4:22 pm
Or if it is new and has nothing on it and will only be used with the Pi, just reformat it to ext4 and get yourself some good speeds. NTFS and FAT aren't very nice on Linux, they work, but ext4 works much better.
Pi with ArchLinux running a minidlna/samba home server
daviewales
Mon Nov 12, 2012 2:43 pm
Sometimes you don't have to specify the filesystem. Try the following, just to see what happens:
mount /dev/sda1 /mnt/usbhd
Incidentally, have you created /mnt/usbhd yet?
ascotguy
Mon Nov 12, 2012 9:07 pm
Thanks for all your help. I now have it working - not really sure what I did.
I think the main thing was to format the usb drive as ntfs on my windows machine works.
