gwaag
how to send email after an event
Tue Sep 25, 2018 4:16 am
I installed
apt-get install ssmtp
apt-get install mailutils
chmod 774 /etc/ssmtp/ssmtp.conf done and edited / configured, properly.
I am able to send / recive a email from command line like this:
echo “Controme is down” | mail -s “ContromeWifidown” [email protected]
The below python script works, no problem.
How can I now incorparate to send email in below python script, that if "Wifi off", it sends a email??
#!/usr/bin/env python3
import subprocess as sp
import os
from time import sleep
status, result = sp.getstatusoutput("ping -c1 -w2 192.168.0.2")   # ping Contromegateway
if(status == 0):
    print("wifi_on")
else:
    print("wifi_off")
HERE CODE LINE FOR EMAIL PLEASE
    sleep(1)
    os.system("pilight-send -p kaku_switch -i 23317358 -u 1 -f")   #  off 3x
    sleep(2)
    sleep(2)
    sleep(5)
    os.system("pilight-send -p kaku_switch -i 23317358 -u 1 -t")   #  on 3x
    sleep(2)
    sleep(2)
    sleep(60)
Andyroo
Re: how to send email after an event
Tue Sep 25, 2018 11:43 am
If you ant to use the command line then have a look at the python subprocess command - this is used to call command line routines from python.
A full explanation is to be found at https://docs.python.org/2/library/subprocess.html
If you want to use a Python module then https://www.pythonforbeginners.com/code ... end-email/ will help.
Let us know how you get on.
gwaag
Tue Sep 25, 2018 5:16 pm
will this work??
import os
import smtplib
status, result = sp.getstatusoutput("sudo ping -c1 -w2 192.168.0.2") # ping Contromegateway
if(status == 0):
    print("wifi_on")
else:
    print("wifi_off")
    s = smtplib.SMTP('smtp server')
    s.login('[email protected]' , 'xxxx')
    s.sendmail(msg['From'], msg['To'], msg.as_string())
    s.quit
    print ("Email sent")
Andyroo
Tue Sep 25, 2018 5:48 pm
Have you had a look at THONNY on the Pi as it lets you step through each line of code to help you debug the program?
The line that will give you an issue is:
as you have not defined From, To and msg
The simplest one I can point you to is http://effbot.org/pyfaq/how-do-i-send-m ... script.htm. Obviously you will need to change server / to / from etc :lol: (i'm being a pain - I know but its a better learning experience to read code than have it on a plate)
gwaag
Tue Sep 25, 2018 6:03 pm
now it works ok.
import time
import socket
import datetime
import sys
import os
import smtplib
from email.mime.text import MIMEText
if(status == 1):
    print("wifi_on")
else:
    print("wifi_off")
#create email
    message = """Wifi Controme down"""
    msg = MIMEText(message)
    msg['subject'] = 'Problem mit Controme'
    msg['from'] = '[email protected]'
    msg['to'] = '[email protected]'
    msg['Date'] = time.strftime('%a, %d %b %Y %H:%M:%S %z')
# send mail
    s = smtplib.SMTP('mail.spinternet.ch')
    s.starttls()
    s.quit
